  <title>CAD Forum discussion (EN) : Problem with srxtextcsv</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : ARKANCE (CAD Studio) applications : Problem with srxtextcsv]]></description>
  <pubDate>Fri, 09 Oct 2026 23:00:30 +0000</pubDate>
  <lastBuildDate>Fri, 12 Dec 2008 16:57:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1439</WebWizForums:feedURL>
   <title><![CDATA[Problem with srxtextcsv : I use Civil 3D Land Desktop Companion...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1439&amp;PID=3925&amp;title=problem-with-srxtextcsv#3925</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=29934">cad24-7user</a><br /><strong>Subject:</strong> 1439<br /><strong>Posted:</strong> 12.Dec.2008 at 16:57<br /><br /><P =Ms&#111;normal style="MARGIN: 0in 0in 10pt"><FONT size=3><FONT color=#000000><FONT face=Calibri>I use Civil 3D Land Desktop Companion 2008.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN></FONT></FONT></FONT></P><P =Ms&#111;normal style="MARGIN: 0in 0in 10pt"><FONT size=3><FONT color=#000000><FONT face=Calibri>What I need to do is change all elevations in a drawing by 0.94 units.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN></FONT></FONT></FONT></P><P =Ms&#111;normal style="MARGIN: 0in 0in 10pt"><FONT size=3><FONT color=#000000><FONT face=Calibri>I found this wonderful application that should be able to take a .csv file and automatically do the find&amp;replace for all text selected.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Whenever I try though, 0/0 entities found and replaced.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>I try to do Exact match because of obvious issues (changing 2.34 to 1.40 would also change 12.34 to 11.40 and then to 10.46 when that number comes around), but 0/0 is achieved again.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>Then using Substring or Regular expression only changes ALL the numbers to ALL the numbers: no change or each text entity will have 800 characters.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN></FONT></FONT></FONT></P><P =Ms&#111;normal style="MARGIN: 0in 0in 10pt"><FONT face=Calibri color=#000000 size=3>I have created the .csv file.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>I had a few hang-ups when Excel automatically formatted numbers as….well, numbers…..instead of text being recognized in the text file as “1.00”,“0.06”.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>It would come out as 1, .06</FONT></P><SPAN style="FONT-SIZE: 11pt; LINE-HEIGHT: 115%; FONT-FAMILY: 'Calibri','sans-serif'; mso-ascii-theme-font: minor-latin; mso-fareast-font-family: Calibri; mso-fareast-theme-font: minor-latin; mso-hansi-theme-font: minor-latin; mso-bidi-font-family: 'Times New Roman'; mso-bidi-theme-font: minor-bidi; mso-ansi-: EN-US; mso-fareast-: EN-US; mso-bidi-: AR-SA"><FONT color=#000000>But now there seems to be some problem with the quotation marks created by Excel.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>The example file that came with the application works fine.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>I tested it.<SPAN style="mso-spacerun: yes">&nbsp; </SPAN>So does this mean that the app is only good for words and not numbers?</FONT></SPAN>]]>
   <pubDate>Fri, 12 Dec 2008 16:57:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1439&amp;PID=3925&amp;title=problem-with-srxtextcsv#3925</guid>
