  <title>CAD Forum discussion (EN) : Text export/import</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Text export/import]]></description>
  <pubDate>Tue, 03 Nov 2026 06:46:45 +0000</pubDate>
  <lastBuildDate>Mon, 21 Oct 2024 15:42:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=14529</WebWizForums:feedURL>
   <title><![CDATA[Text export/import : you can loop over thisdrawing.modelspace...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14529&amp;PID=39813&amp;title=text-export-import#39813</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=973599">ajay1579</a><br /><strong>Subject:</strong> 14529<br /><strong>Posted:</strong> 21.Oct.2024 at 15:42<br /><br />you can loop over thisdrawing.modelspace for acdbtext, collect all text and its insertion point and bounding box extent.&nbsp;<div><br></div><div>with translated text you can set the text other porperies agian using vba</div>]]>
   <pubDate>Mon, 21 Oct 2024 15:42:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14529&amp;PID=39813&amp;title=text-export-import#39813</guid>
   <title><![CDATA[Text export/import : Hi All,I am looking for ways to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14529&amp;PID=39631&amp;title=text-export-import#39631</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=969068">tokintmash</a><br /><strong>Subject:</strong> 14529<br /><strong>Posted:</strong> 16.Aug.2024 at 16:31<br /><br />Hi All,<div><br></div><div>I am looking for ways to export texts from DWG files for translation and importing the translations later to replace those texts.</div><div><br></div><div>Yes, I've found the "Trans" but I was wondering if there are others beside this one that are good? Possibly even as open lisp so I could try and modify the code if necessary. Maybe specify a layer or something.</div><div><br></div><div>I don't require the automatic translation for example, but I&nbsp; do require batch export/import capability as sometimes there can be hundreds of files.</div><div><br></div><div>I need to extract texts and pass them to translators and later replace texts inside DWGs with translations.</div><div><br></div><div>I should also mention that am a total beginner when it comes to CADs. I've managed to export texts using Dataextraction, but haven't managed to replace texts based on excel.</div>]]>
   <pubDate>Fri, 16 Aug 2024 16:31:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14529&amp;PID=39631&amp;title=text-export-import#39631</guid>
