  <title>CAD Forum discussion (EN) : angle and length command</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : angle and length command]]></description>
  <pubDate>Wed, 30 Sep 2026 17:46:02 +0000</pubDate>
  <lastBuildDate>Fri, 06 Mar 2009 22:11:41 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1465</WebWizForums:feedURL>
   <title><![CDATA[angle and length command :    vyasastro wrote:i want adt2006...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4885&amp;title=angle-and-length-command#4885</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=40407">vyasastro</a><br /><strong>Subject:</strong> 1465<br /><strong>Posted:</strong> 06.Mar.2009 at 22:11<br /><br /><img src="https://www.cadforum.cz/forum_en/smileys/smiley17.gif" border="0" align="absmiddle" alt="T&#111;ngue" /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by vyasastro" alt="Originally posted by vyasastro" style="vertical-align: text-bottom;" /> <strong>vyasastro wrote:</strong><br /><br />i want adt2006 tutorial, help me pl.</td></tr></table>]]>
   <pubDate>Fri, 06 Mar 2009 22:11:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4885&amp;title=angle-and-length-command#4885</guid>
   <title><![CDATA[angle and length command : i want adt2006 tutorial, help...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4884&amp;title=angle-and-length-command#4884</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=40407">vyasastro</a><br /><strong>Subject:</strong> 1465<br /><strong>Posted:</strong> 06.Mar.2009 at 22:08<br /><br />i want adt2006 tutorial, help me pl.]]>
   <pubDate>Fri, 06 Mar 2009 22:08:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4884&amp;title=angle-and-length-command#4884</guid>
   <title><![CDATA[angle and length command : What I want to do is click on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4048&amp;title=angle-and-length-command#4048</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30608">dodge</a><br /><strong>Subject:</strong> 1465<br /><strong>Posted:</strong> 23.Dec.2008 at 15:16<br /><br /><P>What I want to do is click on a line and have the bearing and distance stay on the drawing.</P>]]>
   <pubDate>Tue, 23 Dec 2008 15:16:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4048&amp;title=angle-and-length-command#4048</guid>
   <title><![CDATA[angle and length command : I am new to this do you know how...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4047&amp;title=angle-and-length-command#4047</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30608">dodge</a><br /><strong>Subject:</strong> 1465<br /><strong>Posted:</strong> 23.Dec.2008 at 15:12<br /><br /><P>I am new to this do you know how to go about setting that up?</P>]]>
   <pubDate>Tue, 23 Dec 2008 15:12:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4047&amp;title=angle-and-length-command#4047</guid>
   <title><![CDATA[angle and length command : This is the FIELD functionality...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4021&amp;title=angle-and-length-command#4021</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 1465<br /><strong>Posted:</strong> 21.Dec.2008 at 09:43<br /><br />This is the FIELD functionality - fields can dynamically display properties of selected objects.]]>
   <pubDate>Sun, 21 Dec 2008 09:43:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=4021&amp;title=angle-and-length-command#4021</guid>
   <title><![CDATA[angle and length command : I am using 2006. I heard that...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=3999&amp;title=angle-and-length-command#3999</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30608">dodge</a><br /><strong>Subject:</strong> 1465<br /><strong>Posted:</strong> 18.Dec.2008 at 17:52<br /><br />I am using 2006. I heard that there is a command that will let you select a line, and the text will appear next to it on your drawing. Give you the angle and the distance of the line. I am working on section corners and this would be much easier than adding text to each one. does any one know this command??????]]>
   <pubDate>Thu, 18 Dec 2008 17:52:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1465&amp;PID=3999&amp;title=angle-and-length-command#3999</guid>
