  <title>CAD Forum discussion (EN) : Scales with _1</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Scales with _1]]></description>
  <pubDate>Sat, 10 Oct 2026 01:52:26 +0000</pubDate>
  <lastBuildDate>Mon, 27 Apr 2026 14:04:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=14775</WebWizForums:feedURL>
   <title><![CDATA[Scales with _1 : Thanks, I was able to get rid...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14775&amp;PID=40291&amp;title=scales-with-1#40291</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=116047">Junker8</a><br /><strong>Subject:</strong> 14775<br /><strong>Posted:</strong> 27.Apr.2026 at 14:04<br /><br />Thanks, I was able to get rid of them.]]>
   <pubDate>Mon, 27 Apr 2026 14:04:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14775&amp;PID=40291&amp;title=scales-with-1#40291</guid>
   <title><![CDATA[Scales with _1 : You can use the command -SCALELISTEDIT...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14775&amp;PID=40290&amp;title=scales-with-1#40290</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 14775<br /><strong>Posted:</strong> 17.Apr.2026 at 14:43<br /><br />You can use the command -SCALELISTEDIT to reset annotation scales in a single drawing, or the Scale List Cleanup utility or DBXremSL to perform batch cleaning - see the tip:<div>https://www.cadforum.cz/en/qaID.asp?tip=5871</div><div><br><div><br></div></div>]]>
   <pubDate>Fri, 17 Apr 2026 14:43:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14775&amp;PID=40290&amp;title=scales-with-1#40290</guid>
   <title><![CDATA[Scales with _1 : I have hundreds of annotation...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14775&amp;PID=40289&amp;title=scales-with-1#40289</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=116047">Junker8</a><br /><strong>Subject:</strong> 14775<br /><strong>Posted:</strong> 17.Apr.2026 at 14:33<br /><br />I have hundreds of annotation scales named like "1:1000_1" in my drawings. How to remove them? It is too tedious to click them one by one.]]>
   <pubDate>Fri, 17 Apr 2026 14:33:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=14775&amp;PID=40289&amp;title=scales-with-1#40289</guid>
