  <title>CAD Forum discussion (EN) : Question, if anyone can help</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Question, if anyone can help]]></description>
  <pubDate>Sat, 05 Sep 2026 01:34:52 +0000</pubDate>
  <lastBuildDate>Tue, 13 Jan 2009 10:28:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1540</WebWizForums:feedURL>
   <title><![CDATA[Question, if anyone can help : Yes... you can use OLE object...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4257&amp;title=question-if-anyone-can-help#4257</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30578">Imad Habash</a><br /><strong>Subject:</strong> 1540<br /><strong>Posted:</strong> 13.Jan.2009 at 10:28<br /><br />Yes... you can use OLE object command in INSERT pull down menu, i hope that what you mean...<img src="http://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" align="absmiddle" alt="Smile" />]]>
   <pubDate>Tue, 13 Jan 2009 10:28:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4257&amp;title=question-if-anyone-can-help#4257</guid>
   <title><![CDATA[Question, if anyone can help : etransmit was it. Thanks for the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4246&amp;title=question-if-anyone-can-help#4246</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=32332">officeguy</a><br /><strong>Subject:</strong> 1540<br /><strong>Posted:</strong> 12.Jan.2009 at 16:51<br /><br /><P>etransmit was it. Thanks for the help</P><P>&nbsp;</P>]]>
   <pubDate>Mon, 12 Jan 2009 16:51:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4246&amp;title=question-if-anyone-can-help#4246</guid>
   <title><![CDATA[Question, if anyone can help : After you insert an image into...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4236&amp;title=question-if-anyone-can-help#4236</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20343">umesh.rao</a><br /><strong>Subject:</strong> 1540<br /><strong>Posted:</strong> 12.Jan.2009 at 10:24<br /><br />After you insert an image into autocad you need to save your file first.<br>Use imagemanager to detach unwanted images. Save the file once again.<br>Use the e<u>T</u>ransmit command (find it under File menu). Preferably you can accept the defaults and press OK. In the next dialog box, give an appropriate name for your file (I would suggest to accept the default name, which will be the name of the drawing file you are working on and the string " - Standard.zip" added, and press the save button.<br>The file gets saved in the appropriate directory.<br>This file can be used as an attachment to your email.<br>Thus etransmit is a very useful tool.<br><br><img src="https://www.cadforum.cz/forum_en/smileys/smiley20.gif" border="0" align="absmiddle" alt="Thumbs%20Up" /><br><br>]]>
   <pubDate>Mon, 12 Jan 2009 10:24:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4236&amp;title=question-if-anyone-can-help#4236</guid>
   <title><![CDATA[Question, if anyone can help : Maybe you think about ETRANSMIT......]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4222&amp;title=question-if-anyone-can-help#4222</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=20994">Kackac</a><br /><strong>Subject:</strong> 1540<br /><strong>Posted:</strong> 10.Jan.2009 at 00:04<br /><br />Maybe you think about &#091;CMD&#093;ETRANSMIT&#091;/CMD&#093;...<br>]]>
   <pubDate>Sat, 10 Jan 2009 00:04:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4222&amp;title=question-if-anyone-can-help#4222</guid>
   <title><![CDATA[Question, if anyone can help : I used a command once that included...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4221&amp;title=question-if-anyone-can-help#4221</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=32332">officeguy</a><br /><strong>Subject:</strong> 1540<br /><strong>Posted:</strong> 09.Jan.2009 at 21:34<br /><br />I used a command once that included images with a drawing, so when i emailed it, i didnt have to send the image files seperate from the drawing. Any help on this would be appreciated.]]>
   <pubDate>Fri, 09 Jan 2009 21:34:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1540&amp;PID=4221&amp;title=question-if-anyone-can-help#4221</guid>
