  <title>CAD Forum discussion (EN) : Solids and attributes</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Solids and attributes]]></description>
  <pubDate>Wed, 21 Oct 2026 10:02:35 +0000</pubDate>
  <lastBuildDate>Tue, 03 Feb 2009 14:08:18 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1630</WebWizForums:feedURL>
   <title><![CDATA[Solids and attributes :   Reposted: I need to know if...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1630&amp;PID=4473&amp;title=solids-and-attributes#4473</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 1630<br /><strong>Posted:</strong> 03.Feb.2009 at 14:08<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Quote" alt="Quote" style="vertical-align: text-bottom;" /> <strong>Reposted:</strong><DIV>I need to know if i can add attributes to a solid.&nbsp;&nbsp;To use solview and soldraw to do sections, imported solid blocks&nbsp;must be&nbsp; exploded to solids.</DIV><DIV>&nbsp;</DIV><DIV>Is there a work around, software in use is acad 2007</DIV><DIV></td></tr></table></DIV><DIV>Attributes can be attached only to blocks. But you can explode blocks retaining the original attribute values - see:<BR><a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6524" target="_blank">http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6524</A></DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 03 Feb 2009 14:08:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1630&amp;PID=4473&amp;title=solids-and-attributes#4473</guid>
