  <title>CAD Forum discussion (EN) : SPLINE CONVERTION</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : SPLINE CONVERTION]]></description>
  <pubDate>Fri, 04 Sep 2026 17:10:10 +0000</pubDate>
  <lastBuildDate>Thu, 19 Feb 2009 17:38:53 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1693</WebWizForums:feedURL>
   <title><![CDATA[SPLINE CONVERTION : When i convert splines to polylines,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4667&amp;title=spline-convertion#4667</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7263">_Spawn</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 19.Feb.2009 at 17:38<br /><br /><P>When i convert splines to polylines, sometimes, some of the transformed plolynes loose their previous form and turn into stright lines with a whole new form. is there anyway to fix this ??</P><P>&nbsp;</P>]]>
   <pubDate>Thu, 19 Feb 2009 17:38:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4667&amp;title=spline-convertion#4667</guid>
   <title><![CDATA[SPLINE CONVERTION : I loaded the lisps that convert...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4665&amp;title=spline-convertion#4665</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7263">_Spawn</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 19.Feb.2009 at 16:59<br /><br /><P>I loaded the lisps that convert splines into polylines but when i write the comandline it tells me that it is an unknown command.</P><DIV>any help on this???</DIV>]]>
   <pubDate>Thu, 19 Feb 2009 16:59:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4665&amp;title=spline-convertion#4665</guid>
   <title><![CDATA[SPLINE CONVERTION : Please go to &amp;#034;FILE-----Save...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4664&amp;title=spline-convertion#4664</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=38022">tkelly</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 19.Feb.2009 at 14:54<br /><br />Please go to "FILE-----Save As-----File of types - Choose .DXF&nbsp;<DIV>&nbsp;</DIV><DIV>Tom</DIV><DIV><a href="http://www.indovance.com" target="_blank">www.indovance.com</A></DIV>]]>
   <pubDate>Thu, 19 Feb 2009 14:54:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4664&amp;title=spline-convertion#4664</guid>
   <title><![CDATA[SPLINE CONVERTION : Go to Cadalyst site, search spline...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4662&amp;title=spline-convertion#4662</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=37715">mjlsr1</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 19.Feb.2009 at 14:29<br /><br />Go to Cadalyst site, search spline in the "get the code" or hot tips area.&nbsp; There are lisp routines for conversion. <br>http://cadtips.cadalyst.com/node/tiplisting?keywords=spline]]>
   <pubDate>Thu, 19 Feb 2009 14:29:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4662&amp;title=spline-convertion#4662</guid>
   <title><![CDATA[SPLINE CONVERTION : how can I export an Autocad file...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4660&amp;title=spline-convertion#4660</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7263">_Spawn</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 19.Feb.2009 at 10:48<br /><br /><P>how can I export an Autocad file into .dxf?</P><P>&nbsp;</P>]]>
   <pubDate>Thu, 19 Feb 2009 10:48:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4660&amp;title=spline-convertion#4660</guid>
   <title><![CDATA[SPLINE CONVERTION : Export drawing to .DXF format...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4655&amp;title=spline-convertion#4655</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=38022">tkelly</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 19.Feb.2009 at 10:01<br /><br /><P>Export drawing to .DXF format and open the .DXF file .</P><DIV>This should give you the splines converted into lines</DIV><DIV>&nbsp;</DIV><DIV>Tom</DIV><DIV><a href="http://www.indovance.com" target="_blank">www.indovance.com</A></DIV>]]>
   <pubDate>Thu, 19 Feb 2009 10:01:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4655&amp;title=spline-convertion#4655</guid>
   <title><![CDATA[SPLINE CONVERTION : The flatten command is the only...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4645&amp;title=spline-convertion#4645</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=37959">CADtut</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 18.Feb.2009 at 21:25<br /><br />The flatten command is the only way I know of. There is an option <b>not </b>to delete lines, so this may solve the problem you were experiencing! <br><br>Command:<br><i><br>Flatten<br>:remove hidden lines? &lt;No&gt;</i><br><br>I don't tend to use splines, although they can be useful!<br>]]>
   <pubDate>Wed, 18 Feb 2009 21:25:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4645&amp;title=spline-convertion#4645</guid>
   <title><![CDATA[SPLINE CONVERTION : thx a lot ;) but sometimes it...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4639&amp;title=spline-convertion#4639</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7263">_Spawn</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 18.Feb.2009 at 17:16<br /><br />thx a lot ;)&nbsp; but sometimes it destroys or deletes some of the polylines. Is there a way to fix this ??<DIV></DIV><span style="font-size:10px"><br /><br />Edited by _Spawn - 18.Feb.2009 at 17:19</span>]]>
   <pubDate>Wed, 18 Feb 2009 17:16:07 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4639&amp;title=spline-convertion#4639</guid>
   <title><![CDATA[SPLINE CONVERTION : the &amp;#034;flatten&amp;#034; command...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4638&amp;title=spline-convertion#4638</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 18.Feb.2009 at 17:06<br /><br />the "flatten" command from express tools can change spline into polyline .. ;)]]>
   <pubDate>Wed, 18 Feb 2009 17:06:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4638&amp;title=spline-convertion#4638</guid>
   <title><![CDATA[SPLINE CONVERTION : Is there anyway to convert a spline...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4636&amp;title=spline-convertion#4636</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=7263">_Spawn</a><br /><strong>Subject:</strong> 1693<br /><strong>Posted:</strong> 18.Feb.2009 at 15:52<br /><br /><P>Is there anyway to convert a spline line into a simple line or a polyline? Spline lines are extremely dificult to manage, and create a sort of problems that are easily solved if it is a polyline</P><DIV>&nbsp;</DIV><DIV>thx </DIV>]]>
   <pubDate>Wed, 18 Feb 2009 15:52:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1693&amp;PID=4636&amp;title=spline-convertion#4636</guid>
