  <title>CAD Forum discussion (EN) : Freaky Dimensioning Issue</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Freaky Dimensioning Issue]]></description>
  <pubDate>Tue, 27 Oct 2026 03:33:36 +0000</pubDate>
  <lastBuildDate>Thu, 19 Feb 2009 23:30:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1697</WebWizForums:feedURL>
   <title><![CDATA[Freaky Dimensioning Issue : Hi Tom  I had a look at a previous...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4677&amp;title=freaky-dimensioning-issue#4677</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=37456">rdavies1973</a><br /><strong>Subject:</strong> 1697<br /><strong>Posted:</strong> 19.Feb.2009 at 23:30<br /><br />Hi Tom<DIV>&nbsp;</DIV><DIV>I had a look at a previous version of the same project, and that was the exact problem. All resolved.</DIV><DIV>&nbsp;</DIV><DIV>Still not sure how it happened.</DIV>]]>
   <pubDate>Thu, 19 Feb 2009 23:30:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4677&amp;title=freaky-dimensioning-issue#4677</guid>
   <title><![CDATA[Freaky Dimensioning Issue : Check the text size in &amp;#034;Text...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4656&amp;title=freaky-dimensioning-issue#4656</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=38022">tkelly</a><br /><strong>Subject:</strong> 1697<br /><strong>Posted:</strong> 19.Feb.2009 at 10:03<br /><br />Check the text size in "Text style"<DIV>Go to "Format --text style"</DIV><DIV>You might have set default value of text style as 2</DIV><DIV>&nbsp;</DIV><DIV>Hope this help</DIV><DIV>&nbsp;</DIV><DIV>Tom </DIV><DIV>www.indovance.com</DIV>]]>
   <pubDate>Thu, 19 Feb 2009 10:03:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4656&amp;title=freaky-dimensioning-issue#4656</guid>
   <title><![CDATA[Freaky Dimensioning Issue : Hey rdavies1973&amp;#039; I use AutoCAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4649&amp;title=freaky-dimensioning-issue#4649</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=19035">nameci</a><br /><strong>Subject:</strong> 1697<br /><strong>Posted:</strong> 19.Feb.2009 at 05:15<br /><br />Hey rdavies1973'<br />I use AutoCAD 2008. Select the dimstyle that you want and make it current. Type dim, hit space bar, type up (for update), hit space bar, select the whole drawing and hit enter. That should update all of your dimensions to the selected dimstyle.<br /><br />Hope that helps,<br />nameci <img src="https://www.cadforum.cz/forum_en/smileys/smiley1.gif" border="0" align="middle" /> ]]>
   <pubDate>Thu, 19 Feb 2009 05:15:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4649&amp;title=freaky-dimensioning-issue#4649</guid>
   <title><![CDATA[Freaky Dimensioning Issue : Hi all  Just discovered something...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4648&amp;title=freaky-dimensioning-issue#4648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=37456">rdavies1973</a><br /><strong>Subject:</strong> 1697<br /><strong>Posted:</strong> 19.Feb.2009 at 04:37<br /><br />Hi all<DIV>&nbsp;</DIV><DIV>Just discovered something weird that I've never seen before on ACAD (2007).</DIV><DIV>&nbsp;</DIV><DIV>The drawing has a few dimensions already on it and, previously, I could adjust them no worries.</DIV><DIV>&nbsp;</DIV><DIV>I think somewhere down the line I've hit a command because the dimensions aren't behaving themselves.</DIV><DIV>&nbsp;</DIV><DIV>Each time I try to adust a dimension now, the text size jumps from 200 to 2. not just for that dimension, but every dimension usinf that Dimstyle.</DIV><DIV>&nbsp;</DIV><DIV>Any attempted change to the dimension brings the same result, whether it's grip edit, stretch, even changing the arrrowheads.</DIV><DIV>&nbsp;</DIV><DIV>The odd thing is, when I look at the properties, ACAD thinks that the text size is still 200 ... even though it is displaying 2.</DIV>]]>
   <pubDate>Thu, 19 Feb 2009 04:37:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1697&amp;PID=4648&amp;title=freaky-dimensioning-issue#4648</guid>
