  <title>CAD Forum discussion (EN) : editing shortcuts problem</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : editing shortcuts problem]]></description>
  <pubDate>Wed, 21 Oct 2026 20:26:32 +0000</pubDate>
  <lastBuildDate>Fri, 27 Feb 2009 14:34:12 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1732</WebWizForums:feedURL>
   <title><![CDATA[editing shortcuts problem :   aks2 wrote:thanks Arben. the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4778&amp;title=editing-shortcuts-problem#4778</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 1732<br /><strong>Posted:</strong> 27.Feb.2009 at 14:34<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by aks2" alt="Originally posted by aks2" style="vertical-align: text-bottom;" /> <strong>aks2 wrote:</strong><br /><br />thanks Arben. the express tools seem to be loaded; they were loaded the last time I used the program.. <BR><BR>I'm not sure what changing my profile means.. I'm just confused how the program could lose contact with the list of aliases... <BR><BR><BR></td></tr></table> <DIV>&nbsp;</DIV><DIV>Ok&nbsp;&nbsp;check for it in C:\programs files \AutoCAD 200X\Express&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;If it exist tell me again.</DIV>]]>
   <pubDate>Fri, 27 Feb 2009 14:34:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4778&amp;title=editing-shortcuts-problem#4778</guid>
   <title><![CDATA[editing shortcuts problem : thanks Arben. the express tools...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4771&amp;title=editing-shortcuts-problem#4771</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=39061">aks2</a><br /><strong>Subject:</strong> 1732<br /><strong>Posted:</strong> 27.Feb.2009 at 03:41<br /><br />thanks Arben. the express tools seem to be loaded; they were loaded the last time I used the program.. <br /><br />I'm not sure what changing my profile means.. I'm just confused how the program could lose contact with the list of aliases...<br /><br /><br />]]>
   <pubDate>Fri, 27 Feb 2009 03:41:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4771&amp;title=editing-shortcuts-problem#4771</guid>
   <title><![CDATA[editing shortcuts problem :    aks2 wrote:hi (help!)..  I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4752&amp;title=editing-shortcuts-problem#4752</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 1732<br /><strong>Posted:</strong> 26.Feb.2009 at 09:29<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by aks2" alt="Originally posted by aks2" style="vertical-align: text-bottom;" /> <strong>aks2 wrote:</strong><br /><br />hi (help!)..<br><br>I was editing my autocad 2005 shortcuts using the express tool alias editor (express -&gt; tools -&gt; command alias editor). I used the new command shortcuts (d for distance instead of di, etc) and everything seemed fine.<br><br>then today I reopened autocad and it no longer recognizes &gt;any&lt; alias commands, all the edits as well as the commands I didn't edit were gone (it doesn't recognize l for line, etc), and the program cannot locate the alias.exe file. <br><br>could someone help me? thank you!! <br><br><br><br></td></tr></table><br><br>Is loaded&nbsp; Express menu&nbsp; in your program.?<br>or maybe you should change profile .<br>]]>
   <pubDate>Thu, 26 Feb 2009 09:29:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4752&amp;title=editing-shortcuts-problem#4752</guid>
   <title><![CDATA[editing shortcuts problem : hi (help!)..  I was editing my...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4747&amp;title=editing-shortcuts-problem#4747</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=39061">aks2</a><br /><strong>Subject:</strong> 1732<br /><strong>Posted:</strong> 26.Feb.2009 at 04:13<br /><br />hi (help!)..<br /><br />I was editing my autocad 2005 shortcuts using the express tool alias editor (express -&gt; tools -&gt; command alias editor). I used the new command shortcuts (d for distance instead of di, etc) and everything seemed fine.<br /><br />then today I reopened autocad and it no longer recognizes &gt;any&lt; alias commands, all the edits as well as the commands I didn't edit were gone (it doesn't recognize l for line, etc), and the program cannot locate the alias.exe file. <br /><br />could someone help me? thank you!! <br /><br /><br /><br />]]>
   <pubDate>Thu, 26 Feb 2009 04:13:44 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1732&amp;PID=4747&amp;title=editing-shortcuts-problem#4747</guid>
