  <title>CAD Forum discussion (EN) : layout 90 degree</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : layout 90 degree]]></description>
  <pubDate>Sat, 05 Sep 2026 17:21:23 +0000</pubDate>
  <lastBuildDate>Mon, 02 Mar 2009 14:19:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1751</WebWizForums:feedURL>
   <title><![CDATA[layout 90 degree : congratulation .... it&amp;#039;s...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4811&amp;title=layout-90-degree#4811</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=547">Apeiron</a><br /><strong>Subject:</strong> 1751<br /><strong>Posted:</strong> 02.Mar.2009 at 14:19<br /><br /><img src="https://www.cadforum.cz/forum_en/smileys/smiley2.gif" border="0" align="absmiddle" alt="Wink" /><br>congratulation .... it's not verry easy to manage this function from the first time ....... if oyu have others question please ask<br>]]>
   <pubDate>Mon, 02 Mar 2009 14:19:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4811&amp;title=layout-90-degree#4811</guid>
   <title><![CDATA[layout 90 degree : Thanks. Works perfect.  Now...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4810&amp;title=layout-90-degree#4810</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23298">danielito6</a><br /><strong>Subject:</strong> 1751<br /><strong>Posted:</strong> 02.Mar.2009 at 13:22<br /><br />Thanks.<DIV>Works perfect.<img src="http://www.cadforum.cz/forum_en/smileys/smiley17.gif" height="17" width="17" border="0" align="absmiddle" alt="T&#111;ngue" /></DIV><DIV>&nbsp;</DIV><DIV>Now I´m a very happy man.<img src="http://www.cadforum.cz/forum_en/smileys/smiley17.gif" height="17" width="17" border="0" align="absmiddle" alt="T&#111;ngue" /></DIV>]]>
   <pubDate>Mon, 02 Mar 2009 13:22:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4810&amp;title=layout-90-degree#4810</guid>
   <title><![CDATA[layout 90 degree : Hello, you must change the UCS...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4809&amp;title=layout-90-degree#4809</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=547">Apeiron</a><br /><strong>Subject:</strong> 1751<br /><strong>Posted:</strong> 02.Mar.2009 at 11:57<br /><br /><P>Hello,</P><P>you must change the UCS of the model space from viewport ...</P><P>Take care if you don't know how to doit ..... see help about this ... it's easy.</P><P>after you get in viewport and zoom near your building, you have to type UCS on keyboard and then type 3P and after that select a corner (the one you want to be the left one ... down ) -after this step you must select the line you want to be the X axis and after that the line you wabt to be the Y axis --- the last step is to type on keyboard PLAN and use CURRENT and you will have the model plan rotated only in viewport.</P><P>Good luck</P>]]>
   <pubDate>Mon, 02 Mar 2009 11:57:47 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4809&amp;title=layout-90-degree#4809</guid>
   <title><![CDATA[layout 90 degree : Hi   In my model spacei have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4808&amp;title=layout-90-degree#4808</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23298">danielito6</a><br /><strong>Subject:</strong> 1751<br /><strong>Posted:</strong> 02.Mar.2009 at 11:27<br /><br />Hi <DIV>&nbsp;</DIV><DIV>In my mo<FONT face="Times New Roman" color=#000000 size=3>d</FONT>el space&nbsp;i have a building where its rotate 45&nbsp;dregrees, but in my layout i want to have it&nbsp;0 Degrees.</DIV><DIV>How can I do it if i do´t want to&nbsp; change in the modelspace?</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><span style="font-size:10px"><br /><br />Edited by danielito6 - 02.Mar.2009 at 11:30</span>]]>
   <pubDate>Mon, 02 Mar 2009 11:27:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1751&amp;PID=4808&amp;title=layout-90-degree#4808</guid>
