  <title>CAD Forum discussion (EN) : Rusty Fundamentals</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Rusty Fundamentals]]></description>
  <pubDate>Fri, 04 Sep 2026 23:52:12 +0000</pubDate>
  <lastBuildDate>Sat, 14 Mar 2009 16:03:42 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1793</WebWizForums:feedURL>
   <title><![CDATA[Rusty Fundamentals : I found the problem to be the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4964&amp;title=rusty-fundamentals#4964</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23443">Senor Dorado</a><br /><strong>Subject:</strong> 1793<br /><strong>Posted:</strong> 14.Mar.2009 at 16:03<br /><br /><img src="https://www.cadforum.cz/forum_en/smileys/smiley4.gif" border="0" align="absmiddle" alt="Big%20smile" /><br><br>&nbsp;I found the problem to be the Units setting of Decimals and the solution , just as you suggested, to be resetting the Units to Architecture. Also found that the Engineering units setting did the the trick as well.<br><br>&nbsp;You don't know irritating a simple little thing like this can be, especially when you're ready to rock and roll and you can't get er done!<br><br>&nbsp;&nbsp; many thanks<br><br>&nbsp; &nbsp; &nbsp; Senor Dorado <br>]]>
   <pubDate>Sat, 14 Mar 2009 16:03:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4964&amp;title=rusty-fundamentals#4964</guid>
   <title><![CDATA[Rusty Fundamentals : What are your Units settings(UN)?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4962&amp;title=rusty-fundamentals#4962</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=38022">tkelly</a><br /><strong>Subject:</strong> 1793<br /><strong>Posted:</strong> 14.Mar.2009 at 10:04<br /><br /><P style="MARGIN-BOTTOM: 0in">What are your Units settings(UN)? If the drawing units settings “Length type” is set to DECIMAL, then, only the length is to be entered (without the unit e.g. 2 or3 etc.)</P><P style="MARGIN-BOTTOM: 0in">This might be the solution of your problem.</P><P style="MARGIN-BOTTOM: 0in">Again if you want to enter the length in feet or inches (for e.g. 2' or 2” etc.), you will need to set the drawing units to “ARCHITECTURAL”.</P><P style="MARGIN-BOTTOM: 0in">Also, you can reply if you are facing any different kind of problem.</P><P style="MARGIN-BOTTOM: 0in">Enjoy learning!</P><P style="MARGIN-BOTTOM: 0in">Tom</P><DIV><a href="http://www.indovance.com" target="_blank"><FONT color=#0000ff>www.indovance.com</FONT></A></DIV>]]>
   <pubDate>Sat, 14 Mar 2009 10:04:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4962&amp;title=rusty-fundamentals#4962</guid>
   <title><![CDATA[Rusty Fundamentals :     Senor Dorado wrote:I have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4960&amp;title=rusty-fundamentals#4960</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 1793<br /><strong>Posted:</strong> 13.Mar.2009 at 22:41<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Senor Dorado" alt="Originally posted by Senor Dorado" style="vertical-align: text-bottom;" /> <strong>Senor Dorado wrote:</strong><br /><br />I have become rusty on some of the basics of Auto Cad 2007, while learning other drawing programs. Can someone help me with an on going problem that I keep running into.<br><br>&nbsp; My problem is when I start a new dwg. I can not draw a line by merely initiating the line command picking the start point and&nbsp; moving the pointer in the direction required and then entering the length of the line.<br><br>&nbsp; Is this a setting problem or does it have todo with the default template acad.dwt?<br><br>&nbsp;&nbsp; Please help!<br><br>&nbsp;&nbsp;&nbsp;&nbsp; Senor Dorado<br></td></tr></table><br><br>What about when you type line in command window?<br><br><span style="font-size:10px"><br /><br />Edited by Arben.Allaraj - 13.Mar.2009 at 22:42</span>]]>
   <pubDate>Fri, 13 Mar 2009 22:41:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4960&amp;title=rusty-fundamentals#4960</guid>
   <title><![CDATA[Rusty Fundamentals : I have become rusty on some of...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4951&amp;title=rusty-fundamentals#4951</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23443">Senor Dorado</a><br /><strong>Subject:</strong> 1793<br /><strong>Posted:</strong> 12.Mar.2009 at 22:43<br /><br />I have become rusty on some of the basics of Auto Cad 2007, while learning other drawing programs. Can someone help me with an on going problem that I keep running into.<br><br>&nbsp; My problem is when I start a new dwg. I can not draw a line by merely initiating the line command picking the start point and&nbsp; moving the pointer in the direction required and then entering the length of the line.<br><br>&nbsp; Is this a setting problem or does it have todo with the default template acad.dwt?<br><br>&nbsp;&nbsp; Please help!<br><br>&nbsp;&nbsp;&nbsp;&nbsp; Senor Dorado<br>]]>
   <pubDate>Thu, 12 Mar 2009 22:43:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1793&amp;PID=4951&amp;title=rusty-fundamentals#4951</guid>
