  <title>CAD Forum discussion (EN) : AIP 10 to MAX 7</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : AIP 10 to MAX 7]]></description>
  <pubDate>Fri, 11 Sep 2026 01:03:54 +0000</pubDate>
  <lastBuildDate>Wed, 16 Jan 2008 22:17:43 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=187</WebWizForums:feedURL>
   <title><![CDATA[AIP 10 to MAX 7 : archiep,If you looking for the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=921&amp;title=aip-10-to-max-7#921</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=4026">nPower</a><br /><strong>Subject:</strong> 187<br /><strong>Posted:</strong> 16.Jan.2008 at 22:17<br /><br /><font face="Tahoma, Arial, Sans serif">archiep,<br><br>If you looking for the best possible translation from Inventor to Max then you should check out our Power Translator Product.<br><br>http://www.npowersoftware.com/translators/ptoverview.htm<br><br>Cheers<br></font>]]>
   <pubDate>Wed, 16 Jan 2008 22:17:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=921&amp;title=aip-10-to-max-7#921</guid>
   <title><![CDATA[AIP 10 to MAX 7 : Thanks mate. Your the best. By...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=439&amp;title=aip-10-to-max-7#439</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1632">archiep</a><br /><strong>Subject:</strong> 187<br /><strong>Posted:</strong> 19.Oct.2007 at 03:21<br /><br />Thanks mate.<br />Your the best.<br />By the way, im with inventor for 3 years now and started to work on max now. other software that were using now are autocad 2008 and Rhinocerous 4.]]>
   <pubDate>Fri, 19 Oct 2007 03:21:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=439&amp;title=aip-10-to-max-7#439</guid>
   <title><![CDATA[AIP 10 to MAX 7 : You can read Inventor files directly...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=434&amp;title=aip-10-to-max-7#434</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 187<br /><strong>Posted:</strong> 18.Oct.2007 at 19:25<br /><br />You can read Inventor files directly in 3ds max - see:<DIV><a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3943" target="_blank">http://www.cadforum.cz/cadforum_en/qaID.asp?tip=3943</A></DIV>]]>
   <pubDate>Thu, 18 Oct 2007 19:25:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=434&amp;title=aip-10-to-max-7#434</guid>
   <title><![CDATA[AIP 10 to MAX 7 : Whats the best way to have a flawless...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=428&amp;title=aip-10-to-max-7#428</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1632">archiep</a><br /><strong>Subject:</strong> 187<br /><strong>Posted:</strong> 18.Oct.2007 at 12:45<br /><br />Whats the best way to have a flawless conversion of my inventor assembly to max. I tried iges and the it will be in one layer only on max.]]>
   <pubDate>Thu, 18 Oct 2007 12:45:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=187&amp;PID=428&amp;title=aip-10-to-max-7#428</guid>
