  <title>CAD Forum discussion (EN) : 3D view at startup ?</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 3D view at startup ?]]></description>
  <pubDate>Fri, 04 Sep 2026 14:21:46 +0000</pubDate>
  <lastBuildDate>Sun, 12 Apr 2009 06:55:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=1890</WebWizForums:feedURL>
   <title><![CDATA[3D view at startup ? : I&amp;#039;m using 2008 but 2009 is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5258&amp;title=3d-view-at-startup#5258</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=41618">jmnueva</a><br /><strong>Subject:</strong> 1890<br /><strong>Posted:</strong> 12.Apr.2009 at 06:55<br /><br /><P>I'm using 2008 but 2009 is just an enhancement, try this:</P><DIV>File/New</DIV><DIV></DIV><DIV></DIV><DIV></DIV>&nbsp;&nbsp;&nbsp; It will show the <DIV>Templates/select acad.dwt or acadiso.dwt</DIV><DIV></DIV><DIV>&nbsp;&nbsp;&nbsp; Then save the drawing to make it the default template.</DIV>]]>
   <pubDate>Sun, 12 Apr 2009 06:55:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5258&amp;title=3d-view-at-startup#5258</guid>
   <title><![CDATA[3D view at startup ? : Thank you for the answer.  I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5222&amp;title=3d-view-at-startup#5222</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=45444">Stage</a><br /><strong>Subject:</strong> 1890<br /><strong>Posted:</strong> 08.Apr.2009 at 01:51<br /><br />Thank you for the answer.<DIV>&nbsp;</DIV><DIV>I resetted to profile to default and restarted my Autocad and I still have the same problem. All the toolbars are Ok but the object view is still in 3D mode.&nbsp; I have managed to diseable the ViewCube but that doesnt change my object view.&nbsp; Still getting that grey background. And it really is in my Autocad because I can open the same file with another workstation and the Object view is ok ( Black background and all my shapes, filling etc are there )</DIV><DIV>&nbsp;</DIV><DIV>Any other ideas ?</DIV>]]>
   <pubDate>Wed, 08 Apr 2009 01:51:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5222&amp;title=3d-view-at-startup#5222</guid>
   <title><![CDATA[3D view at startup ? : Right click your mouse in the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5221&amp;title=3d-view-at-startup#5221</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30236">msplcdykee69</a><br /><strong>Subject:</strong> 1890<br /><strong>Posted:</strong> 07.Apr.2009 at 22:56<br /><br />Right click your mouse in the center of your screen or over your command line and then click options&gt; go to the Profile tab make sure the right profile is being used in your autocad if not select it and set it to current.&nbsp; If your not using the right profile make sure you go to the start up icon on your desktop right click it and&nbsp;click on properties.<DIV>&nbsp;</DIV><DIV>&nbsp;&nbsp;&nbsp;"C:\Program Files\AutoCAD Civil 3D 2008\acad.exe" /p "<FONT color=#ff0000>Change this name to the profile you wish to run as the default</FONT>"</DIV><DIV>&nbsp;</DIV><DIV>your target name may differ somewhat but here is how you get it to start the defualt profile you wish.</DIV><DIV>&nbsp;</DIV><DIV>If you do not have a default pofile then change your workspace off of 3D Modeling and select your 2D modeling options.&nbsp; the export the profile on your computer this way if this trouble ever arises you can reimport and fix it automaticly.&nbsp; </DIV><DIV>&nbsp;</DIV><DIV>If nothing else works you can select the default profile and click reset this will bring up the default autocad settings.</DIV>]]>
   <pubDate>Tue, 07 Apr 2009 22:56:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5221&amp;title=3d-view-at-startup#5221</guid>
   <title><![CDATA[3D view at startup ? : Hi all!  This is my first post...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5219&amp;title=3d-view-at-startup#5219</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=45444">Stage</a><br /><strong>Subject:</strong> 1890<br /><strong>Posted:</strong> 07.Apr.2009 at 22:30<br /><br />Hi all!<DIV>&nbsp;</DIV><DIV>This is my first post here, I tried to search into the forum but I cant seem to find my answer even tought I'm sure it have been answered before.&nbsp; I'm using Autocad 2009 and I seem to be stuck on the 3D view ( with the gray background instead of black ) by default when I open any DWG. I dont even knoe how to switch back to normal 2D view since I never used 3D in autocad.&nbsp; And I know even less how to set this 2D view by default.</DIV><DIV>&nbsp;</DIV><DIV>Thanks for your help!</DIV>]]>
   <pubDate>Tue, 07 Apr 2009 22:30:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=1890&amp;PID=5219&amp;title=3d-view-at-startup#5219</guid>
