  <title>CAD Forum discussion (EN) : Thick lines in blocks</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Revit : Thick lines in blocks]]></description>
  <pubDate>Wed, 21 Oct 2026 23:25:16 +0000</pubDate>
  <lastBuildDate>Tue, 31 Jul 2007 14:51:51 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=20</WebWizForums:feedURL>
   <title><![CDATA[Thick lines in blocks : You may check the line thickness...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=20&amp;PID=38&amp;title=thick-lines-in-blocks#38</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 20<br /><strong>Posted:</strong> 31.Jul.2007 at 14:51<br /><br />You may check the line thickness setting but it may be also caused by your units setting (the model is too small) or scale (the model is displayed in a small scale).<DIV>See also:</DIV><DIV><a href="http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4975" target="_blank">http://www.cadforum.cz/cadforum_en/qaID.asp?tip=4975</A></DIV>]]>
   <pubDate>Tue, 31 Jul 2007 14:51:51 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=20&amp;PID=38&amp;title=thick-lines-in-blocks#38</guid>
   <title><![CDATA[Thick lines in blocks : DWG blocks imported into Revit...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=20&amp;PID=36&amp;title=thick-lines-in-blocks#36</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=53">JacqP</a><br /><strong>Subject:</strong> 20<br /><strong>Posted:</strong> 31.Jul.2007 at 14:44<br /><br />DWG blocks imported into Revit display in very thick lines. Is there any setting for this?]]>
   <pubDate>Tue, 31 Jul 2007 14:44:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=20&amp;PID=36&amp;title=thick-lines-in-blocks#36</guid>
