  <title>CAD Forum discussion (EN) : Question about paper space</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Question about paper space]]></description>
  <pubDate>Thu, 03 Sep 2026 21:09:09 +0000</pubDate>
  <lastBuildDate>Mon, 18 May 2009 08:12:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2003</WebWizForums:feedURL>
   <title><![CDATA[Question about paper space :  Thanks a lot !i have never notice...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2003&amp;PID=5575&amp;title=question-about-paper-space#5575</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=49642">Hitsugaya81</a><br /><strong>Subject:</strong> 2003<br /><strong>Posted:</strong> 18.May.2009 at 08:12<br /><br />Thanks a lot !<br>i have never notice the effect of this option in layer manager.<br><br>What do you meens about view port process?<br>Could you give me the command line? (maybe I know this functionnality but don't understand you)<br><br>Thanks a lot.<br><br>Best regards.<br><span style="font-size:10px"><br /><br />Edited by Hitsugaya81 - 18.May.2009 at 08:15</span>]]>
   <pubDate>Mon, 18 May 2009 08:12:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2003&amp;PID=5575&amp;title=question-about-paper-space#5575</guid>
   <title><![CDATA[Question about paper space : Use Paperspace and Viewport process....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2003&amp;PID=5554&amp;title=question-about-paper-space#5554</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=38022">tkelly</a><br /><strong>Subject:</strong> 2003<br /><strong>Posted:</strong> 15.May.2009 at 16:58<br /><br />Use Paperspace and Viewport process. So when you go through the viewport you can freeze desired objects that need not be seen on paper space/layout. These objects are seen in Model space though.<DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>Tom</DIV><DIV><a href="http://www.indovance.com" target="_blank">www.indovance.com</A></DIV>]]>
   <pubDate>Fri, 15 May 2009 16:58:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2003&amp;PID=5554&amp;title=question-about-paper-space#5554</guid>
   <title><![CDATA[Question about paper space : Hi everyoneIm looking for method...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2003&amp;PID=5541&amp;title=question-about-paper-space#5541</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=49642">Hitsugaya81</a><br /><strong>Subject:</strong> 2003<br /><strong>Posted:</strong> 15.May.2009 at 10:30<br /><br />Hi everyone<br><br>Im looking for method to associate specifics objects to presentation.<br>Forthe moment I'm make a copy in a different layer, in a differentlocation in the object space to get distincts objects for eachpresentation.<br><br>Like associated material with object, how can Idefine witch object will be displayed for witch presentation? (associateobject to presentation)<br><br>thanks for all informations you could bring to me.]]>
   <pubDate>Fri, 15 May 2009 10:30:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2003&amp;PID=5541&amp;title=question-about-paper-space#5541</guid>
