  <title>CAD Forum discussion (EN) : Cad2004 problem</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Cad2004 problem]]></description>
  <pubDate>Tue, 20 Oct 2026 03:29:11 +0000</pubDate>
  <lastBuildDate>Fri, 19 Jun 2009 22:10:03 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2037</WebWizForums:feedURL>
   <title><![CDATA[Cad2004 problem : Dear asli.dost /Newbie Thank...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5944&amp;title=cad2004-problem#5944</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=53011">ameralmayahi</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 19.Jun.2009 at 22:10<br /><br />Dear <a href="http://www.cadforum.cz/forum_en/member_profile.asp?PF=56668&FID=2" target="_blank"><strong>asli.dost</strong></A> /Newbie<DIV>Thank you a lot for your solution</DIV><DIV>I applied it and it worked well !!<img src="http://www.cadforum.cz/forum_en/smileys/smiley32.gif" height="17" width="18" border="0" align="absmiddle" alt="Clap" /></DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Fri, 19 Jun 2009 22:10:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5944&amp;title=cad2004-problem#5944</guid>
   <title><![CDATA[Cad2004 problem :  Try to open drawing in autocad...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5889&amp;title=cad2004-problem#5889</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=56668">asli.dost</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 17.Jun.2009 at 05:31<br /><br /><DIV><P =Ms&#111;normal style="MARGIN: 0in 0in 0pt"><FONT size=3><FONT color=#000000><FONT face="Times New Roman">Try to open drawing in autocad 2007.but open autocad 2007 and <strong>recover </strong>seclet file and start recovering .I think your file will be recover and save other location and change <strong>file type change .Autocad2007<SPAN style="mso-spacerun: yes"></SPAN></strong></FONT></FONT></FONT></P><P =Ms&#111;normal style="MARGIN: 0in 0in 0pt"><FONT face="Times New Roman" color=#000000 size=3>Try and enjoy</FONT></P></DIV>]]>
   <pubDate>Wed, 17 Jun 2009 05:31:12 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5889&amp;title=cad2004-problem#5889</guid>
   <title><![CDATA[Cad2004 problem : It seems there is something to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5783&amp;title=cad2004-problem#5783</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=48574">AmerieWhite</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 09.Jun.2009 at 04:58<br /><br />It seems there is something to do with the path name. You can try to put the draiwng on Desktop and see if it works.]]>
   <pubDate>Tue, 09 Jun 2009 04:58:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5783&amp;title=cad2004-problem#5783</guid>
   <title><![CDATA[Cad2004 problem : Thanks a lot brother Amerie White,I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5671&amp;title=cad2004-problem#5671</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=53011">ameralmayahi</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 27.May.2009 at 01:08<br /><br />Thanks a lot brother Amerie White,<br>I have tried the program you sent me but I'm keep getting the message (attached snap shot) every time I want to access to the CAD files.<br>Please see the attached file on the following link:<br>http://rs517.rapidshare.com/files/237604743/1.bmp<br><br>Please any advice?<br><br><img src="file:///C:/DOCUME%7E1/AMER/LOCALS%7E1/Temp/moz-screenshot.jpg" border="0" /><img src="file:///C:/DOCUME%7E1/AMER/LOCALS%7E1/Temp/moz-screenshot-1.jpg" border="0" /><img src="file:///C:/DOCUME%7E1/AMER/LOCALS%7E1/Temp/moz-screenshot-2.jpg" border="0" />]]>
   <pubDate>Wed, 27 May 2009 01:08:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5671&amp;title=cad2004-problem#5671</guid>
   <title><![CDATA[Cad2004 problem :  Try to &amp;#039;recover&amp;#039; the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5662&amp;title=cad2004-problem#5662</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=48574">AmerieWhite</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 26.May.2009 at 14:57<br /><br />Try to 'recover' the drawing in AutoCAD or try this converter to repair the drawing file:<br><a href="http://" target="_blank"><b><a target="_blank"><i>AutoDWG DWG DXF Converter</i></a></b></a> (<a href="http://www.autodwg.com/DWG_DXF_C&#111;nverter/" target="_blank">http://www.autodwg.com/DWG_DXF_Converter/</a>)<br>With this converter, you just need to add the draiwng in the list, choose <i>version conversion</i> and output 2004 version. with clicking on convert button, drawing file in 2004 version will be generated.<br><span style="font-size: 10px;"><br></span><span style="font-size:10px"><br /><br />Edited by AmerieWhite - 26.May.2009 at 15:33</span>]]>
   <pubDate>Tue, 26 May 2009 14:57:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5662&amp;title=cad2004-problem#5662</guid>
   <title><![CDATA[Cad2004 problem : Hii tkelly,Thanks for your response.I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5644&amp;title=cad2004-problem#5644</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=53011">ameralmayahi</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 24.May.2009 at 16:19<br /><br />Hii tkelly,<br>Thanks for your response.<br>I have checked the files size and there were all more than 100Kb.<br>I had created them in Autocade2004 and I tried to open them in AutoCad2004 as well.<br>&nbsp;<br>]]>
   <pubDate>Sun, 24 May 2009 16:19:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5644&amp;title=cad2004-problem#5644</guid>
   <title><![CDATA[Cad2004 problem : I think you made some damage to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5643&amp;title=cad2004-problem#5643</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=38022">tkelly</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 24.May.2009 at 07:53<br /><br />I think you made some damage to the file or that file was opened with higher version of AutoCAD and was not saved back to previous version.<DIV>Try opening with higher version of Autocad.</DIV><DIV>Check the size of file does that file . If it is leass tahn 10 KB or so then the file is corrupted.</DIV><DIV>&nbsp;</DIV><DIV>Tom</DIV><DIV><a href="http://www.indovance.com" target="_blank">www.indovance.com</A></DIV>]]>
   <pubDate>Sun, 24 May 2009 07:53:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5643&amp;title=cad2004-problem#5643</guid>
   <title><![CDATA[Cad2004 problem : Hi Guys,A year ago I had created...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5642&amp;title=cad2004-problem#5642</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=53011">ameralmayahi</a><br /><strong>Subject:</strong> 2037<br /><strong>Posted:</strong> 24.May.2009 at 03:31<br /><br />Hi Guys,<br>&nbsp;A year ago I had created AutoCad 2004 files, now I can't open them on my computer,any idea?<br>I 'm getting a message saying " couldn't open the specify file". Even I can't preview them before opening them.<br><br><br>Thanks<br>]]>
   <pubDate>Sun, 24 May 2009 03:31:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2037&amp;PID=5642&amp;title=cad2004-problem#5642</guid>
