  <title>CAD Forum discussion (EN) : Radius dimensions</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Radius dimensions]]></description>
  <pubDate>Mon, 26 Oct 2026 11:35:50 +0000</pubDate>
  <lastBuildDate>Wed, 24 Oct 2007 13:21:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=206</WebWizForums:feedURL>
   <title><![CDATA[Radius dimensions : Hi Cadmonkey  If you go to the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=470&amp;title=radius-dimensions#470</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1784">Shyguy</a><br /><strong>Subject:</strong> 206<br /><strong>Posted:</strong> 24.Oct.2007 at 13:21<br /><br />Hi Cadmonkey<DIV>&nbsp;</DIV><DIV>If you go to the 'downloads' section and then put a search in for AutoCad 2008, scroll to 'Patches &amp; Updates' and click on the 3rd entry down in the list.</DIV><DIV>Click on the 'Info' section on the right hand side and have a read through, i'm sure these an entry in there that talks about the radii dimensioning issues.</DIV><DIV>&nbsp;</DIV><DIV>Then on the left hand side is the downloadable file</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Wed, 24 Oct 2007 13:21:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=470&amp;title=radius-dimensions#470</guid>
   <title><![CDATA[Radius dimensions : That sounds encouraging, do you...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=469&amp;title=radius-dimensions#469</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1794">CADMONKEY</a><br /><strong>Subject:</strong> 206<br /><strong>Posted:</strong> 24.Oct.2007 at 11:51<br /><br />That sounds encouraging, do you mean the patch lives on the forum site?]]>
   <pubDate>Wed, 24 Oct 2007 11:51:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=469&amp;title=radius-dimensions#469</guid>
   <title><![CDATA[Radius dimensions : Not sure if this is the right...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=468&amp;title=radius-dimensions#468</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1784">Shyguy</a><br /><strong>Subject:</strong> 206<br /><strong>Posted:</strong> 24.Oct.2007 at 09:19<br /><br />Not sure if this is the right answer, as i am new to R2008 and having my own problems, but i noticed that the patch (which you can get from here) does modify radii dimension issues.<DIV>&nbsp;</DIV><DIV>Worth a try as it also corrects alot of other issues as well.</DIV><DIV>&nbsp;</DIV><DIV>All the best</DIV>]]>
   <pubDate>Wed, 24 Oct 2007 09:19:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=468&amp;title=radius-dimensions#468</guid>
   <title><![CDATA[Radius dimensions : Acad 2008 seems to display radius...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=465&amp;title=radius-dimensions#465</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1794">CADMONKEY</a><br /><strong>Subject:</strong> 206<br /><strong>Posted:</strong> 24.Oct.2007 at 04:58<br /><br />Acad 2008 seems to display radius dimensions differently for left and right arcs, one appears as 'normal' with the arrow head on the described arc, yet for the other it sticks the arrow head out on a continuation of the radius.&nbsp; <img src="http://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="absmiddle" alt="C&#111;nfused" /><DIV>Would appreciate any tips on how to return to 'normal' settings.</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Wed, 24 Oct 2007 04:58:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=206&amp;PID=465&amp;title=radius-dimensions#465</guid>
