  <title>CAD Forum discussion (EN) : Pan Different</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Pan Different]]></description>
  <pubDate>Mon, 26 Oct 2026 19:35:32 +0000</pubDate>
  <lastBuildDate>Tue, 09 Jun 2009 20:39:27 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2080</WebWizForums:feedURL>
   <title><![CDATA[Pan Different : ok so i changed the middle button...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5803&amp;title=pan-different#5803</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55547">cMaD</a><br /><strong>Subject:</strong> 2080<br /><strong>Posted:</strong> 09.Jun.2009 at 20:39<br /><br />ok so i changed the middle button in options to other and selected middle button instead of autoscroll in the mouse driver. and it works now! thanks for the direction...]]>
   <pubDate>Tue, 09 Jun 2009 20:39:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5803&amp;title=pan-different#5803</guid>
   <title><![CDATA[Pan Different : Thanks, I tried settingMBUTTONPAN...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5790&amp;title=pan-different#5790</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55547">cMaD</a><br /><strong>Subject:</strong> 2080<br /><strong>Posted:</strong> 09.Jun.2009 at 15:19<br /><br /><P>Thanks, I tried setting&nbsp;MBUTTONPAN to 0 and 1 and it made no difference. </P><DIV>My mouse settings seem fine in control panels?</DIV>]]>
   <pubDate>Tue, 09 Jun 2009 15:19:22 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5790&amp;title=pan-different#5790</guid>
   <title><![CDATA[Pan Different : Try to set the MBUTTONPAN variable,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5784&amp;title=pan-different#5784</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 2080<br /><strong>Posted:</strong> 09.Jun.2009 at 07:22<br /><br />Try to set the &#091;VAR&#093;MBUTTONPAN&#091;/VAR&#093; variable, set your mouse driver to "Microsoft Office compatible".]]>
   <pubDate>Tue, 09 Jun 2009 07:22:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5784&amp;title=pan-different#5784</guid>
   <title><![CDATA[Pan Different : Hi Hopefully someone can help...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5782&amp;title=pan-different#5782</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=55547">cMaD</a><br /><strong>Subject:</strong> 2080<br /><strong>Posted:</strong> 08.Jun.2009 at 22:41<br /><br />Hi<DIV>Hopefully someone can help me!</DIV><DIV>I have just started using autocad 2006 and the pan is different when i hold down the wheel- im used to a hand that lets you move around, and now i have a strange arrow that moves me in the opposite direction?</DIV><DIV>How to I change the middle button to this RTPAN?</DIV><DIV>Thank you!!</DIV>]]>
   <pubDate>Mon, 08 Jun 2009 22:41:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2080&amp;PID=5782&amp;title=pan-different#5782</guid>
