  <title>CAD Forum discussion (EN) : Dim texts anti-aliasing bug</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Dim texts anti-aliasing bug]]></description>
  <pubDate>Thu, 22 Oct 2026 16:08:06 +0000</pubDate>
  <lastBuildDate>Fri, 17 Jul 2009 13:21:16 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2190</WebWizForums:feedURL>
   <title><![CDATA[Dim texts anti-aliasing bug : hmm i have one dim style for all...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6184&amp;title=dim-texts-antialiasing-bug#6184</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27131">a_t_s</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 17.Jul.2009 at 13:21<br /><br />hmm i have one dim style for all dimensions(non-annotative, but scaled), all of them is in one layer with lineweight - Default (0.25mm)&nbsp; then i changed it to 0.15mm nothing changed, still some dimensions are plotted thicker than others. then to 0.05mm and still nothing..<br>In search for answer in some posts over the net i read that it my occur because of drawing when Z axis is rotated a little or smth like that..<br>]]>
   <pubDate>Fri, 17 Jul 2009 13:21:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6184&amp;title=dim-texts-antialiasing-bug#6184</guid>
   <title><![CDATA[Dim texts anti-aliasing bug : I have replied to your email Tariq...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6181&amp;title=dim-texts-antialiasing-bug#6181</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30236">msplcdykee69</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 17.Jul.2009 at 04:18<br /><br />I have replied to your email Tariq check the dwg with your plot style and see if it fixes your proplem text. if it does then I will post here for you A-T-S this way you can see if this is your smae problem.&nbsp; What I did was go into his DWG and created a dim style with all the properties he was using and then selected all the text and changed it to all the same properties.&nbsp; his text layer was calling out an actual thickness of 0.15mm and that might be trying to overide his plot style. check this with your dwg and let me know.&nbsp; I have a few ideas more ,but sometimes this might be all it is.<DIV>&nbsp;</DIV><DIV>I hope this helps you both.</DIV>]]>
   <pubDate>Fri, 17 Jul 2009 04:18:58 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6181&amp;title=dim-texts-antialiasing-bug#6181</guid>
   <title><![CDATA[Dim texts anti-aliasing bug : Hi Shawn    I send u file on...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6162&amp;title=dim-texts-antialiasing-bug#6162</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 16.Jul.2009 at 10:38<br /><br />Hi Shawn <DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>I send u file on your adress and check it because a-t-s&nbsp; have some problum.</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>Thanks</DIV><span style="font-size:10px"><br /><br />Edited by tariq - 16.Jul.2009 at 10:39</span>]]>
   <pubDate>Thu, 16 Jul 2009 10:38:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6162&amp;title=dim-texts-antialiasing-bug#6162</guid>
   <title><![CDATA[Dim texts anti-aliasing bug : i&amp;#039;m running autocad architecture...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6136&amp;title=dim-texts-antialiasing-bug#6136</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27131">a_t_s</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 13.Jul.2009 at 09:37<br /><br />i'm running autocad architecture 2009. But unfortunately i can't send you that file, it's large project and kind a classified :) sorry]]>
   <pubDate>Mon, 13 Jul 2009 09:37:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6136&amp;title=dim-texts-antialiasing-bug#6136</guid>
   <title><![CDATA[Dim texts anti-aliasing bug : What version of CAD are you running?...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6130&amp;title=dim-texts-antialiasing-bug#6130</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=30236">msplcdykee69</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 10.Jul.2009 at 22:39<br /><br />What version of CAD are you running?&nbsp; I have a few ideas of what it might be. Can you send me a copy in an email and I can look at it and then be able to tell you if it is what I think it is.&nbsp; my email is <a href="mailto:msplcdykee69@yahoo.com" target="_blank">msplcdykee69@yahoo.com</A>&nbsp; Send it to me and I can look at it and get it back to you A.S.A.P.]]>
   <pubDate>Fri, 10 Jul 2009 22:39:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6130&amp;title=dim-texts-antialiasing-bug#6130</guid>
   <title><![CDATA[Dim texts anti-aliasing bug : c&amp;#039;mon guys ! any ideas ?! ...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6126&amp;title=dim-texts-antialiasing-bug#6126</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27131">a_t_s</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 10.Jul.2009 at 11:29<br /><br />c'mon guys ! any ideas ?!]]>
   <pubDate>Fri, 10 Jul 2009 11:29:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6126&amp;title=dim-texts-antialiasing-bug#6126</guid>
   <title><![CDATA[Dim texts anti-aliasing bug :   Some of my dimensions seems...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6103&amp;title=dim-texts-antialiasing-bug#6103</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=27131">a_t_s</a><br /><strong>Subject:</strong> 2190<br /><strong>Posted:</strong> 07.Jul.2009 at 09:42<br /><br /><img src="https://www.cadforum.cz/forum_en/smileys/smiley19.gif" border="0" align="absmiddle" alt="Cry" /> Some of my dimensions seems to be like non-anti-aliased and some anti-aliased, i don't know how i get them to be different but when printed some are bold and some doesn't ! Same mached properties, same layer, same text style. How to get them the same (I'd prefer non-anti-aliased, the bolder ones). I really hope some of you PRO's can help me! <br><img src="http://u1.imgupload.co.uk/1246921200/9820_bug.jpg" height="772" width="1071" border="0" /><br><span style="font-size:10px"><br /><br />Edited by a_t_s - 07.Jul.2009 at 09:50</span>]]>
   <pubDate>Tue, 07 Jul 2009 09:42:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2190&amp;PID=6103&amp;title=dim-texts-antialiasing-bug#6103</guid>
