  <title>CAD Forum discussion (EN) : broken section veiws</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : broken section veiws]]></description>
  <pubDate>Tue, 29 Sep 2026 07:37:02 +0000</pubDate>
  <lastBuildDate>Mon, 24 Aug 2009 21:34:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2209</WebWizForums:feedURL>
   <title><![CDATA[broken section veiws : You can do the following: 1. In...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2209&amp;PID=6528&amp;title=broken-section-veiws#6528</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=33698">victorot</a><br /><strong>Subject:</strong> 2209<br /><strong>Posted:</strong> 24.Aug.2009 at 21:34<br /><br />You can do the following:<br />1. In .idw enviornment select the view that you wanna create a "broken section view".<br />2. Click on CREATE SKETCH tool<br />3. Draw a sketch that will be used as reference.<br />4. Finish Sketch<br />5. Select the BREACK OUT tool<br />6. Select the VIEW<br />7. "Boundary" -&gt; select the profile (sketch)<br />8. "Depth" -&gt; Reference depth to create the "break" the reference can be taken of another VIEW, or simply entry with some value.<br />9. "Display" -&gt; visualization option<br />10. Click OK.<br /><br /><br />]]>
   <pubDate>Mon, 24 Aug 2009 21:34:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2209&amp;PID=6528&amp;title=broken-section-veiws#6528</guid>
   <title><![CDATA[broken section veiws : I&amp;#039;m using Inventor 11, SP2.  I&amp;#039;m...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2209&amp;PID=6158&amp;title=broken-section-veiws#6158</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=60738">dam0927</a><br /><strong>Subject:</strong> 2209<br /><strong>Posted:</strong> 15.Jul.2009 at 21:37<br /><br />I'm using Inventor 11, SP2.<DIV>&nbsp;</DIV><DIV>I'm having trouble creating a broken section view.&nbsp; Here's what I've done so far.&nbsp; </DIV><DIV>&nbsp;</DIV><DIV>I have created a Work Plain through a tapped hole in the model.&nbsp; I then created a sketch in the model on the new Work Plain, sketching a closed section.&nbsp; Everything appears to be saved correctly.</DIV><DIV>&nbsp;</DIV><DIV>In the drawing, I select the view in which to display the broken out section and receive the message "This view does not contain a sketch with a closed profile."</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Wed, 15 Jul 2009 21:37:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2209&amp;PID=6158&amp;title=broken-section-veiws#6158</guid>
