  <title>CAD Forum discussion (EN) : DXF read problem!!!</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : DXF read problem!!!]]></description>
  <pubDate>Sun, 06 Sep 2026 05:48:02 +0000</pubDate>
  <lastBuildDate>Tue, 18 Aug 2009 22:48:13 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2319</WebWizForums:feedURL>
   <title><![CDATA[DXF read problem!!! : Thanks for the reply!!  I&amp;#039;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6455&amp;title=dxf-read-problem#6455</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=64798">spklive</a><br /><strong>Subject:</strong> 2319<br /><strong>Posted:</strong> 18.Aug.2009 at 22:48<br /><br />Thanks for the reply!!<DIV>&nbsp;</DIV><DIV>I' ll try and other CAD programs!!</DIV>]]>
   <pubDate>Tue, 18 Aug 2009 22:48:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6455&amp;title=dxf-read-problem#6455</guid>
   <title><![CDATA[DXF read problem!!! : I see - the &amp;#034;multi format&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6454&amp;title=dxf-read-problem#6454</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 2319<br /><strong>Posted:</strong> 18.Aug.2009 at 22:38<br /><br />I see - the "multi format" refers to that the&nbsp;DXF format is usable in multiple appliactions. Both DXF and 3DS files are Autodesk formats and they should be readable in AutoCAD.]]>
   <pubDate>Tue, 18 Aug 2009 22:38:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6454&amp;title=dxf-read-problem#6454</guid>
   <title><![CDATA[DXF read problem!!! : Thanks for the reply Vladimir!!   Maybe...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6453&amp;title=dxf-read-problem#6453</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=64798">spklive</a><br /><strong>Subject:</strong> 2319<br /><strong>Posted:</strong> 18.Aug.2009 at 21:54<br /><br />Thanks for the reply Vladimir!!<img src="https://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" align="absmiddle" alt="Smile" /><DIV></DIV><DIV>&nbsp;</DIV><DIV>Maybe you have right! This model i downloaded <a href="http://www.fallingpixel.com/3d-models/11061" target="_blank">http://www.fallingpixel.com/3d-models/11061</A></DIV><DIV>i opened .3ds!</DIV><DIV>3ds is the same with .dxf? Is there any difference?</DIV><DIV>&nbsp;</DIV><DIV>I'm not familiar with CAD!! I need this file to be exported to .sat, to open with CFD programs!! But when i export .3ds there is a message that says&nbsp;the items i&nbsp;selected are not solids!</DIV><DIV>&nbsp;</DIV><DIV>Do you have any idea?</DIV><DIV>&nbsp;</DIV><DIV>Thanks friend!!!</DIV>]]>
   <pubDate>Tue, 18 Aug 2009 21:54:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6453&amp;title=dxf-read-problem#6453</guid>
   <title><![CDATA[DXF read problem!!! : It is probably a file in a different...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6452&amp;title=dxf-read-problem#6452</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 2319<br /><strong>Posted:</strong> 18.Aug.2009 at 21:45<br /><br />It is probably a file in a different file format (just the same extension). There is no "multi format" for AutoCAD DXF files.]]>
   <pubDate>Tue, 18 Aug 2009 21:45:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6452&amp;title=dxf-read-problem#6452</guid>
   <title><![CDATA[DXF read problem!!! : Hi guys,  I need your help!!! I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6451&amp;title=dxf-read-problem#6451</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=64798">spklive</a><br /><strong>Subject:</strong> 2319<br /><strong>Posted:</strong> 18.Aug.2009 at 21:42<br /><br />Hi guys,<DIV>&nbsp;</DIV><DIV>I need your help!!!</DIV><DIV>I downloaded a cad file (.DXF multi format) from internet. I use AutoCAD 2002 but when i open this file there is&nbsp;the message: "the file is currently in use or is read-only. Would you like to open the file read-only?" I press "yes" and then AutoCAD writes "improper the entry name LUCE.1 on line.86. Invalid or incomplete DXF input-drawing discarded." and it doesn't open!!!</DIV><DIV>I don't know what happens?<img src="http://www.cadforum.cz/forum_en/smileys/smiley5.gif" height="17" width="17" border="0" align="absmiddle" alt="C&#111;nfused" /></DIV><DIV>what is DXF multi format???</DIV><DIV>Can anyone help me??</DIV><DIV>&nbsp;</DIV><DIV>Thanks!!!!</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 18 Aug 2009 21:42:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2319&amp;PID=6451&amp;title=dxf-read-problem#6451</guid>
