  <title>CAD Forum discussion (EN) : 09 menu help</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 09 menu help]]></description>
  <pubDate>Sat, 05 Sep 2026 05:08:21 +0000</pubDate>
  <lastBuildDate>Mon, 24 Aug 2009 16:11:06 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2322</WebWizForums:feedURL>
   <title><![CDATA[09 menu help : Hi I think you are looking for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2322&amp;PID=6517&amp;title=09-menu-help#6517</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18035">Bassman</a><br /><strong>Subject:</strong> 2322<br /><strong>Posted:</strong> 24.Aug.2009 at 16:11<br /><br /><P>Hi</P><DIV>I think you are looking for the CUI file should be located under the C drive at the following location </DIV><DIV>"Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Support"</DIV><DIV>Changed from the .MNU in 2009 Hope this helps<img src="http://www.cadforum.cz/forum_en/smileys/smiley10.gif" height="17" width="17" border="0" align="absmiddle" alt="Star" /></DIV>]]>
   <pubDate>Mon, 24 Aug 2009 16:11:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2322&amp;PID=6517&amp;title=09-menu-help#6517</guid>
   <title><![CDATA[09 menu help : Hi, I&amp;#039;m coming from 00 to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2322&amp;PID=6459&amp;title=09-menu-help#6459</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=64963">Prodago</a><br /><strong>Subject:</strong> 2322<br /><strong>Posted:</strong> 19.Aug.2009 at 20:28<br /><br />Hi, I'm coming from 00 to 09 and I'm used to being able to manipulate the .mns or .mnu file. but I can't find these files. All I'm trying to do is to load a lsp routine. I've opened acad2009doc.lsp and tried loading it in this file but autocad rejects. However, when I'm in acad I can manual load it and it works. I'm also using "shortcom" and it loads the file but for some reason will not load "tedit" which is the lsp that I'm trying to get to work. Ultimately I'd like to just use keystrokes to get into that command but will settle for using the shift/middle button menu....BUT I can't find out how to alter this menu either.<DIV>please advise</DIV>]]>
   <pubDate>Wed, 19 Aug 2009 20:28:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2322&amp;PID=6459&amp;title=09-menu-help#6459</guid>
