  <title>CAD Forum discussion (EN) : AutoCAD Template at startup</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : AutoCAD Template at startup]]></description>
  <pubDate>Sat, 05 Sep 2026 17:57:33 +0000</pubDate>
  <lastBuildDate>Fri, 28 Aug 2009 10:28:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2332</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD Template at startup : Arben,  bingo.  The file path...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6568&amp;title=autocad-template-at-startup#6568</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 28.Aug.2009 at 10:28<br /><br />Arben,<br /><br />bingo. <br />The file path appeared for a second under the command line.<br /><br />Great<br />Thanks a lot]]>
   <pubDate>Fri, 28 Aug 2009 10:28:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6568&amp;title=autocad-template-at-startup#6568</guid>
   <title><![CDATA[AutoCAD Template at startup :   Kajito wrote:danielito, thanks...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6567&amp;title=autocad-template-at-startup#6567</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 27.Aug.2009 at 23:14<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Kajito" alt="Originally posted by Kajito" style="vertical-align: text-bottom;" /> <strong>Kajito wrote:</strong><br /><br />danielito, <BR><BR>thanks for trying, but as I wrote above, I tried this as one of the first things. <BR>Once again, I'm not trying to set default template, I want to know template is loaded at Autocad startup.</td></tr></table> <DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>In fact when AutoCAD is loading check about anything under command line.</DIV><DIV>&nbsp;</DIV><DIV>Shoul you see what file is?</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Thu, 27 Aug 2009 23:14:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6567&amp;title=autocad-template-at-startup#6567</guid>
   <title><![CDATA[AutoCAD Template at startup : danielito,  thanks for trying,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6565&amp;title=autocad-template-at-startup#6565</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 27.Aug.2009 at 19:13<br /><br />danielito,<br /><br />thanks for trying, but as I wrote above, I tried this as one of the first things.<br />Once again, I'm not trying to set default template, I want to know template is loaded at Autocad startup.<span style="font-size:10px"><br /><br />Edited by Kajito - 27.Aug.2009 at 19:14</span>]]>
   <pubDate>Thu, 27 Aug 2009 19:13:55 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6565&amp;title=autocad-template-at-startup#6565</guid>
   <title><![CDATA[AutoCAD Template at startup : Hi  command: options  select...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6553&amp;title=autocad-template-at-startup#6553</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=227">danielito</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 27.Aug.2009 at 09:24<br /><br />Hi<DIV>&nbsp;</DIV><DIV>command: options</DIV><DIV>&nbsp;</DIV><DIV>select : FILES&nbsp;&nbsp; </DIV><DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; Template settings</DIV><DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; default template file name for Qnew</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Thu, 27 Aug 2009 09:24:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6553&amp;title=autocad-template-at-startup#6553</guid>
   <title><![CDATA[AutoCAD Template at startup : I did check the properties. It...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6514&amp;title=autocad-template-at-startup#6514</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 24.Aug.2009 at 14:42<br /><br />I did check the properties. It says:<br />"C:\Program Files\AutoCAD 2006\UserDataCache\"<br />But that doesn't really help as it doesnt give me answer which template is loaded at autocad startup. ]]>
   <pubDate>Mon, 24 Aug 2009 14:42:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6514&amp;title=autocad-template-at-startup#6514</guid>
   <title><![CDATA[AutoCAD Template at startup :    Kajito wrote:that was one...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6512&amp;title=autocad-template-at-startup#6512</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 24.Aug.2009 at 14:12<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Kajito" alt="Originally posted by Kajito" style="vertical-align: text-bottom;" /> <strong>Kajito wrote:</strong><br /><br />that was one of the first things I checked, but the field is empty  <img src="https://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="middle" /> <br>I even added cirlce to each template to see which one is loaded and guess what, the circle was not there  <img src="https://www.cadforum.cz/forum_en/smileys/smiley36.gif" border="0" align="middle" /> <br><br></td></tr></table><br><br>Check the AutoCAD Icon properties.<br>]]>
   <pubDate>Mon, 24 Aug 2009 14:12:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6512&amp;title=autocad-template-at-startup#6512</guid>
   <title><![CDATA[AutoCAD Template at startup : that was one of the first things...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6499&amp;title=autocad-template-at-startup#6499</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 22.Aug.2009 at 09:37<br /><br />that was one of the first things I checked, but the field is empty  <img src="https://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="middle" /> <br />I even added cirlce to each template to see which one is loaded and guess what, the circle was not there  <img src="https://www.cadforum.cz/forum_en/smileys/smiley36.gif" border="0" align="middle" /> <br /><br />]]>
   <pubDate>Sat, 22 Aug 2009 09:37:31 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6499&amp;title=autocad-template-at-startup#6499</guid>
   <title><![CDATA[AutoCAD Template at startup :   Kajito wrote:Hi Arben, Thanks...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6497&amp;title=autocad-template-at-startup#6497</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 22.Aug.2009 at 00:14<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Kajito" alt="Originally posted by Kajito" style="vertical-align: text-bottom;" /> <strong>Kajito wrote:</strong><br /><br />Hi Arben,<br />Thanks for reply<br /><br />I dont think that will solve smth because I'm trying to figure out which template is loaded by default, not to set up default template.<br /><br /></td></tr></table> <br /><br />Go to tools--&gt;options---&gt;files check about Qnew?]]>
   <pubDate>Sat, 22 Aug 2009 00:14:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6497&amp;title=autocad-template-at-startup#6497</guid>
   <title><![CDATA[AutoCAD Template at startup : Hi Arben, Thanks for reply  I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6493&amp;title=autocad-template-at-startup#6493</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23910">Kajito</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 21.Aug.2009 at 16:49<br /><br />Hi Arben,<br />Thanks for reply<br /><br />I dont think that will solve smth because I'm trying to figure out which template is loaded by default, not to set up default template.<br /><br />]]>
   <pubDate>Fri, 21 Aug 2009 16:49:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6493&amp;title=autocad-template-at-startup#6493</guid>
   <title><![CDATA[AutoCAD Template at startup :   Kajito wrote:Hi everybody,  I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6492&amp;title=autocad-template-at-startup#6492</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 2332<br /><strong>Posted:</strong> 21.Aug.2009 at 16:36<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Kajito" alt="Originally posted by Kajito" style="vertical-align: text-bottom;" /> <strong>Kajito wrote:</strong><br /><br />Hi everybody,<br /><br />I believe I have simple question and I hope somebody has a simple answer ;).<br />I have an issue which is related I belive to a template. We use in the office CADS detailing suite. When start Autocad, you get a new drawing (based on some kind of template). In this drawing everything is fine, but when I choose another drawing based on any other template, certain things like dimension are suddenly incorrect.<br />I tried to edit templates to see which one is loaded at startup but it was none of them.<br />I tried to google this with no result.<br />I know there is an option for qnew template but this field is left empty.<br /><br />Can please anybody help?<br />Thank you</td></tr></table> <br /><br />Click with the right button of mouse over AutoCAD ICON on desktop and go to target path and type the name of your file template see this example.<br />"c:\program files\autodesk\acad200x""your file.dwt" <br /><br />]]>
   <pubDate>Fri, 21 Aug 2009 16:36:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2332&amp;PID=6492&amp;title=autocad-template-at-startup#6492</guid>
