  <title>CAD Forum discussion (EN) : Model and Layout</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Model and Layout]]></description>
  <pubDate>Fri, 04 Sep 2026 22:20:03 +0000</pubDate>
  <lastBuildDate>Sat, 29 Aug 2009 13:03:02 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2362</WebWizForums:feedURL>
   <title><![CDATA[Model and Layout : Hi, Set variable PSLTSCALE to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2362&amp;PID=6585&amp;title=model-and-layout#6585</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=64780">jorgeanjos</a><br /><strong>Subject:</strong> 2362<br /><strong>Posted:</strong> 29.Aug.2009 at 13:03<br /><br /><P>Hi,</P><P>Set variable PSLTSCALE to 0 and use REGENALL to update the linetype scales.</P><P>PSLTSCALE = 0&nbsp;- Linetype dash lengths are based on the drawing units of the space in which the objects were created (Model or Paper).</P><P>PSLTSCALE = 1 -&nbsp;Linetype dash lengths are based on paper space drawing units and linetype scales may change in viewports with differents zooms.</P><P><BR>Hope That Helps<BR></P>]]>
   <pubDate>Sat, 29 Aug 2009 13:03:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2362&amp;PID=6585&amp;title=model-and-layout#6585</guid>
   <title><![CDATA[Model and Layout : Hi, I have a problem, I work in...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2362&amp;PID=6581&amp;title=model-and-layout#6581</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=50981">tupac8</a><br /><strong>Subject:</strong> 2362<br /><strong>Posted:</strong> 28.Aug.2009 at 20:53<br /><br />Hi, <br><br>I have a problem, I work in a model space and when i look to my work in a Paper Space (Layout) some line lost the scale.<br><br>How can I fix this??<br>]]>
   <pubDate>Fri, 28 Aug 2009 20:53:27 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2362&amp;PID=6581&amp;title=model-and-layout#6581</guid>
