  <title>CAD Forum discussion (EN) : New Material - Inventor 2008</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : New Material - Inventor 2008]]></description>
  <pubDate>Fri, 03 Jul 2026 04:43:56 +0000</pubDate>
  <lastBuildDate>Wed, 10 Mar 2010 22:18:24 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2474</WebWizForums:feedURL>
   <title><![CDATA[New Material - Inventor 2008 : It sounds like Vault is the culpret,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=8881&amp;title=new-material-inventor-2008#8881</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=70478">mrmojo</a><br /><strong>Subject:</strong> 2474<br /><strong>Posted:</strong> 10.Mar.2010 at 22:18<br /><br /><DIV>It sounds like Vault is the culpret, you may want to run the instalation disk and do a repair.</DIV><DIV>&nbsp;</DIV><DIV>Mark Randa</DIV><DIV>The Open Design Project</DIV><DIV><a href="http://opendesignproject.org/Materials/" target="_blank" rel="nofollow">http://opendesignproject.org/Materials/</A></DIV>]]>
   <pubDate>Wed, 10 Mar 2010 22:18:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=8881&amp;title=new-material-inventor-2008#8881</guid>
   <title><![CDATA[New Material - Inventor 2008 : I have encountered problem with...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=8853&amp;title=new-material-inventor-2008#8853</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=70060">PavolK</a><br /><strong>Subject:</strong> 2474<br /><strong>Posted:</strong> 10.Mar.2010 at 15:16<br /><br />I have encountered problem with connection to CC. However, I found tricky workaround. <br>When I create new material I save it into that special xml file. Then, when creating new part I import that xml file in Styles Formatting dialog which makes the material available in materials list on File \ Properties dialog.<br>]]>
   <pubDate>Wed, 10 Mar 2010 15:16:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=8853&amp;title=new-material-inventor-2008#8853</guid>
   <title><![CDATA[New Material - Inventor 2008 : You must have a read/write library...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=6861&amp;title=new-material-inventor-2008#6861</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=70478">mrmojo</a><br /><strong>Subject:</strong> 2474<br /><strong>Posted:</strong> 29.Sep.2009 at 02:17<br /><br /><P style="MARGIN: 0in 0in 10pt" =Ms&#111;normal><FONT face=Calibri><FONT color=#000000><SPAN style="LINE-HEIGHT: 115%; FONT-SIZE: 9pt; mso-ansi-: EN" lang=EN>You must have a read/write library enabled for the project, then after you create the new style you must save it to the CC. In Inventor 2010 all of the commands are on the Manage tab on the Styles and Standards tab. On 2008, I think it is on the same drop-down as the CC editor.</SPAN><B style="mso-bidi-font-weight: normal"><SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 9pt"><?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></SPAN></B></FONT></FONT></P><P style="MARGIN: 0in 0in 10pt" =Ms&#111;normal><SPAN style="LINE-HEIGHT: 115%; FONT-FAMILY: 'Arial','sans-serif'; FONT-SIZE: 8pt"><FONT color=#000000>Mojo<BR clear=all>The Open Design Project<BR clear=all></FONT><a href="http://opendesignproject.org/Inventor/Tutorials/iDoor_Tutorial/index.htm" target="_blank"><FONT color=#800080>http://opendesignproject.org/Inventor/Tutorials/iDoor_Tutorial/index.htm</FONT></A><o:p></o:p></SPAN></P><P>&nbsp;</P>]]>
   <pubDate>Tue, 29 Sep 2009 02:17:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=6861&amp;title=new-material-inventor-2008#6861</guid>
   <title><![CDATA[New Material - Inventor 2008 :  Hi all, is there any way to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=6825&amp;title=new-material-inventor-2008#6825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=70060">PavolK</a><br /><strong>Subject:</strong> 2474<br /><strong>Posted:</strong> 25.Sep.2009 at 13:58<br /><br />Hi all, is there any way to specify a new material globally in Inventor 2008? To have it stored in file and be able to select it any time for any .ipt file. I can only create new material for one part (.ipt file) but I must define it again for another .ipt file.&nbsp; Thank you for any suggestion.<br><span style="font-size:10px"><br /><br />Edited by PavolK - 25.Sep.2009 at 13:59</span>]]>
   <pubDate>Fri, 25 Sep 2009 13:58:17 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2474&amp;PID=6825&amp;title=new-material-inventor-2008#6825</guid>
