  <title>CAD Forum discussion (EN) : XREF file</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : XREF file]]></description>
  <pubDate>Mon, 02 Nov 2026 08:09:40 +0000</pubDate>
  <lastBuildDate>Wed, 14 Oct 2009 04:46:28 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2516</WebWizForums:feedURL>
   <title><![CDATA[XREF file : thanks a lot ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2516&amp;PID=6983&amp;title=xref-file#6983</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=71666">zarzar</a><br /><strong>Subject:</strong> 2516<br /><strong>Posted:</strong> 14.Oct.2009 at 04:46<br /><br />thanks a lot]]>
   <pubDate>Wed, 14 Oct 2009 04:46:28 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2516&amp;PID=6983&amp;title=xref-file#6983</guid>
   <title><![CDATA[XREF file : Go to toolbar menus click oninsert...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2516&amp;PID=6939&amp;title=xref-file#6939</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23429">Ferna</a><br /><strong>Subject:</strong> 2516<br /><strong>Posted:</strong> 08.Oct.2009 at 19:51<br /><br />Go to toolbar menus click on&nbsp;insert then on the 11 item from the top to the bottom you can find a command "Xref Manager" then click on it and you can find a chart there and on right side of the chart you can see a button says&nbsp;"Attach" then you can proceed&nbsp;&nbsp;to do attach the Xref drawing to the you you are working on.<DIV>Hopefully&nbsp;this instructions&nbsp;will help you a bit.</DIV>]]>
   <pubDate>Thu, 08 Oct 2009 19:51:05 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2516&amp;PID=6939&amp;title=xref-file#6939</guid>
   <title><![CDATA[XREF file : Howcan iattach the XREF file? ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2516&amp;PID=6928&amp;title=xref-file#6928</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=71666">zarzar</a><br /><strong>Subject:</strong> 2516<br /><strong>Posted:</strong> 07.Oct.2009 at 06:39<br /><br />How&nbsp;can i&nbsp;attach the XREF file?]]>
   <pubDate>Wed, 07 Oct 2009 06:39:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2516&amp;PID=6928&amp;title=xref-file#6928</guid>
