  <title>CAD Forum discussion (EN) : Diameter &amp; Radius Dimension Placement Editing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Diameter &amp; Radius Dimension Placement Editing]]></description>
  <pubDate>Mon, 07 Sep 2026 11:35:55 +0000</pubDate>
  <lastBuildDate>Tue, 20 Oct 2009 20:47:23 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2563</WebWizForums:feedURL>
   <title><![CDATA[Diameter &amp; Radius Dimension Placement Editing : Hi all. I am new to this site....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2563&amp;PID=7057&amp;title=diameter-radius-dimension-placement-editing#7057</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=74233">toolm8kr</a><br /><strong>Subject:</strong> 2563<br /><strong>Posted:</strong> 20.Oct.2009 at 20:47<br /><br />Hi all. I am new to this site. I am using AutoCAD 2000 running on windows xp sp3. When I create diameter and radius dimensions I am able to place them normally. When I try to edit the positions using the grips, the dimension text will only move toward and away from the arc but will not rotate around the center point.<DIV>&nbsp;</DIV><DIV>The only way I am able to get around this is by rotating the dimension using the rotate command which takes forever.</DIV><DIV>&nbsp;</DIV><DIV>I was running the same software on XP SP2 and never had this problem. It was only when I installed on a new machine running XP SP3.</DIV><DIV>&nbsp;</DIV><DIV>Has anyone had a similar problem?</DIV><DIV>&nbsp;</DIV><DIV>Thanks</DIV>]]>
   <pubDate>Tue, 20 Oct 2009 20:47:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2563&amp;PID=7057&amp;title=diameter-radius-dimension-placement-editing#7057</guid>
