  <title>CAD Forum discussion (EN) : .PDF PRINT</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : .PDF PRINT]]></description>
  <pubDate>Wed, 28 Oct 2026 20:36:01 +0000</pubDate>
  <lastBuildDate>Tue, 17 Nov 2009 20:17:29 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2666</WebWizForums:feedURL>
   <title><![CDATA[.PDF PRINT : it could be a pen style table...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7338&amp;title=pdf-print#7338</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=61756">tulip3D</a><br /><strong>Subject:</strong> 2666<br /><strong>Posted:</strong> 17.Nov.2009 at 20:17<br /><br />it could be a pen style table issue...<DIV></DIV>or settings within adobe, in the printer/plotter secton, select you adobe pdf printer. then click on properties to the right, then click on device and document settings, then click custom properties. hope that helps <img src="http://www.cadforum.cz/forum_en/smileys/smiley20.gif" height="17" width="23" border="0" align="absmiddle" alt="Thumbs%20Up" />]]>
   <pubDate>Tue, 17 Nov 2009 20:17:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7338&amp;title=pdf-print#7338</guid>
   <title><![CDATA[.PDF PRINT : Ron, Txs, for try to help me...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7329&amp;title=pdf-print#7329</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23429">Ferna</a><br /><strong>Subject:</strong> 2666<br /><strong>Posted:</strong> 16.Nov.2009 at 15:34<br /><br /><P>Ron,</P><P>Txs, for try to help me but it unfortunately didn't work, I think I have to wait until somebody help me with this problem.</P><P>TXS</P>]]>
   <pubDate>Mon, 16 Nov 2009 15:34:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7329&amp;title=pdf-print#7329</guid>
   <title><![CDATA[.PDF PRINT : Hi Ferna, Click on the layout...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7308&amp;title=pdf-print#7308</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=18399">Ron C</a><br /><strong>Subject:</strong> 2666<br /><strong>Posted:</strong> 13.Nov.2009 at 16:00<br /><br /><P>Hi Ferna,</P><DIV>Click on the layout outline, right click, pick Shade Plot, pick As Displayed.</DIV><DIV>&nbsp;</DIV><DIV>Hope this works.</DIV>]]>
   <pubDate>Fri, 13 Nov 2009 16:00:02 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7308&amp;title=pdf-print#7308</guid>
   <title><![CDATA[.PDF PRINT : HI EVERYONE, I&amp;#039;M HAVING...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7307&amp;title=pdf-print#7307</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23429">Ferna</a><br /><strong>Subject:</strong> 2666<br /><strong>Posted:</strong> 13.Nov.2009 at 15:48<br /><br />HI EVERYONE,<DIV>I'M HAVING A PROBLEM, EVERY TIME I PRINT MY DRWGS. IN .pdf. WHEN I TRY TO PRINT FROM MY LAYOUTS THE DRWGS.&nbsp;WHICH CONTAIN GRADIENT COLORS DON'T SHOW UP IN THE .pdf FILE BUT WHEN I TRY IN MODEL SPACE, IT WILL PRINT EVERYTHING BEAUTIFUL, COULD YOU PLEASE HELP ME WITH THIS BECAUSE JUST FOR NOW THE PROBLEM IS SOLVED BUT NOT IN A RIGHT WAY AND MUST OF MY DRWGS ARE IN LAYOUT AND ALL THE SET UP ARE IN LAYOUT AND I KNOW THIS GOING TO CAUSE ME A LOT OF PROBLEM LATER ON.</DIV><DIV>TXS</DIV>]]>
   <pubDate>Fri, 13 Nov 2009 15:48:56 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2666&amp;PID=7307&amp;title=pdf-print#7307</guid>
