  <title>CAD Forum discussion (EN) : DXF - ASM500 FLASH QUESTION</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : DXF - ASM500 FLASH QUESTION]]></description>
  <pubDate>Wed, 04 Nov 2026 12:12:46 +0000</pubDate>
  <lastBuildDate>Tue, 20 Nov 2007 16:05:46 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=273</WebWizForums:feedURL>
   <title><![CDATA[DXF - ASM500 FLASH QUESTION : Hello all! My first post here,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=273&amp;PID=630&amp;title=dxf-asm500-flash-question#630</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2543">copperhead</a><br /><strong>Subject:</strong> 273<br /><strong>Posted:</strong> 20.Nov.2007 at 16:05<br /><br /><P>Hello all! My first post here, hope you can help. I am trying to convert my ACAD files to Gerber using ASM500. The only problem that I am having is getting the ASM5oo to "FLASH" the circles. I believe that I am not preparing my dxf file properly. I believe that my circles need to be "BLOCKS" for ASM500 to "FLASH" them. I am making the circles into blocks in ACAD using the 'wblock' command wich writes the circle to a file as a block. Then I 'insert' the circle block into my layout.</P><DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; When I do the translation in ASM500, then I query the circle, it tells me that the circle is not a flash&nbsp;but a&nbsp;'trace' 'circle', it should&nbsp;say that it is a flash. I <strong>did</strong> flash all circles when I&nbsp;set up my aperture list in asm500, so now I am at a loss. Hope someone can help.</DIV><DIV>&nbsp;</DIV><DIV>Thanks&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; </DIV>]]>
   <pubDate>Tue, 20 Nov 2007 16:05:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=273&amp;PID=630&amp;title=dxf-asm500-flash-question#630</guid>
