  <title>CAD Forum discussion (EN) : Change Double-Click Actions</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : RSS Feeds : Change Double-Click Actions]]></description>
  <pubDate>Tue, 15 Sep 2026 10:00:50 +0000</pubDate>
  <lastBuildDate>Mon, 23 Nov 2009 14:50:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2738</WebWizForums:feedURL>
   <title><![CDATA[Change Double-Click Actions : I&amp;#039;m sure you&amp;#039;ve noticed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2738&amp;PID=7429&amp;title=change-doubleclick-actions#7429</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=81157">LTunlimited RSS</a><br /><strong>Subject:</strong> 2738<br /><strong>Posted:</strong> 23.Nov.2009 at 14:50<br /><br />I'm sure you've noticed that when you double-click on certain objects in your drawings, certain commands start. Double-clicking on text opens the text editor, double-clicking on a block opens the  the Attribute Editor or the Block Editor (if the block doesn't have attributes), etc.But what if you don't like the default action? For example, double-clicking on a dimension launches the Properties palette by default. But I'm much more likely to be editing the dimension text than I am to be changing one of its properties. (Adding notes like TYP. or V.I.F. of course, NOT changing the default number!) So I'd rather that double-clicking on a dimension launched the text editor instead.To change this, I'll go into the CUI, look for Double-Click Actions, right-click, and choose New.  I'll call the new action Dimension, and under Object Name, enter DIMENSION. This object name is the DXF name of the object -- fortunately, it usually corresponds to the object name as you know it.  Now, I need to add the command I want to my new action. To do this, I can search or browse the command list, then drag-and-drop the command onto the action. (Watch out -- you want "Text, Edit" or DDEDIT here. Dimension Text Edit and Mtext Edit will NOT give you the same results.)  That's it! Now, after you click OK, double-clicking a dimension will open its text for editing instead of opening the Properties palette. And of course, this method works for adding just about any action to any kind of object (although it helps your sanity if the two are related).<p><i>Go to the <a href="http://feedproxy.google.com/~r/LtUnlimited/~3/slO-fe5rnt8/change-doubleclick-actions.html">original post...</a></i></p>]]>
   <pubDate>Mon, 23 Nov 2009 14:50:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2738&amp;PID=7429&amp;title=change-doubleclick-actions#7429</guid>
