  <title>CAD Forum discussion (EN) : hidden lines in paperspace</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : hidden lines in paperspace]]></description>
  <pubDate>Thu, 05 Nov 2026 03:36:40 +0000</pubDate>
  <lastBuildDate>Thu, 21 Jan 2010 15:48:33 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2810</WebWizForums:feedURL>
   <title><![CDATA[hidden lines in paperspace :   peter.m wrote:Check that the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=8134&amp;title=hidden-lines-in-paperspace#8134</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=82126">Tankman</a><br /><strong>Subject:</strong> 2810<br /><strong>Posted:</strong> 21.Jan.2010 at 15:48<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by peter.m" alt="Originally posted by peter.m" style="vertical-align: text-bottom;" /> <strong>peter.m wrote:</strong><br /><br />Check that the&nbsp; PSLTS (paper space line type scale) is set to 0, being set to 1 would course your current problem</td></tr></table> <DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>Peter:</DIV><DIV>&nbsp;</DIV><DIV>PSLTS should be zero? Is set to 1 would "course" your current problem?</DIV><DIV>&nbsp;</DIV><DIV>Should PSLTS be set to 1 to "solve" the problem?</DIV>]]>
   <pubDate>Thu, 21 Jan 2010 15:48:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=8134&amp;title=hidden-lines-in-paperspace#8134</guid>
   <title><![CDATA[hidden lines in paperspace : Check that the PSLTS (paper space...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=7893&amp;title=hidden-lines-in-paperspace#7893</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=88859">peter.m</a><br /><strong>Subject:</strong> 2810<br /><strong>Posted:</strong> 07.Jan.2010 at 14:09<br /><br />Check that the&nbsp; PSLTS (paper space line type scale) is set to 0, being set to 1 would course your current problem]]>
   <pubDate>Thu, 07 Jan 2010 14:09:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=7893&amp;title=hidden-lines-in-paperspace#7893</guid>
   <title><![CDATA[hidden lines in paperspace : Type LTS atCommandandchange the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=7848&amp;title=hidden-lines-in-paperspace#7848</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2359">Rman</a><br /><strong>Subject:</strong> 2810<br /><strong>Posted:</strong> 05.Jan.2010 at 09:04<br /><br />Type LTS at&nbsp;Command&nbsp;and&nbsp;change the linetype scale factor.]]>
   <pubDate>Tue, 05 Jan 2010 09:04:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=7848&amp;title=hidden-lines-in-paperspace#7848</guid>
   <title><![CDATA[hidden lines in paperspace : Drawing a 3rd angle projection...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=7558&amp;title=hidden-lines-in-paperspace#7558</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=79077">lawshe</a><br /><strong>Subject:</strong> 2810<br /><strong>Posted:</strong> 04.Dec.2009 at 12:14<br /><br />Drawing a 3rd angle projection and in model space I have made some lines dashed to show hidden objects but in paper space the lines are continuous. Can anyone help? Thanks in advance]]>
   <pubDate>Fri, 04 Dec 2009 12:14:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2810&amp;PID=7558&amp;title=hidden-lines-in-paperspace#7558</guid>
