  <title>CAD Forum discussion (EN) : paper space problems</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : paper space problems]]></description>
  <pubDate>Wed, 28 Oct 2026 15:42:44 +0000</pubDate>
  <lastBuildDate>Tue, 08 Dec 2009 13:36:35 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2811</WebWizForums:feedURL>
   <title><![CDATA[paper space problems : Hi If you goto paper space view...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2811&amp;PID=7597&amp;title=paper-space-problems#7597</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=84432">LJames</a><br /><strong>Subject:</strong> 2811<br /><strong>Posted:</strong> 08.Dec.2009 at 13:36<br /><br />Hi<DIV></DIV>If you goto paper space view and click the model/paper button at the bottom of your screen and make sure it shows model. This will activate the viewport. Then goto the FORMAT menu and select Linetype. Next untick the box in the bottom left of of the dialogue box ((Use paper space units for scaling)). This will match your model units to paper space.<img src="http://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" align="absmiddle" alt="Smile" />]]>
   <pubDate>Tue, 08 Dec 2009 13:36:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2811&amp;PID=7597&amp;title=paper-space-problems#7597</guid>
   <title><![CDATA[paper space problems : Drawing a 3rd angle projection...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2811&amp;PID=7559&amp;title=paper-space-problems#7559</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=79077">lawshe</a><br /><strong>Subject:</strong> 2811<br /><strong>Posted:</strong> 04.Dec.2009 at 12:21<br /><br />Drawing a 3rd angle projection and in model space I have made some lines dashed to show hidden objects but in paper space the lines are continuous. Can anyone help? Thanks]]>
   <pubDate>Fri, 04 Dec 2009 12:21:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2811&amp;PID=7559&amp;title=paper-space-problems#7559</guid>
