  <title>CAD Forum discussion (EN) : Flange Issue - Flat pattern...</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : Flange Issue - Flat pattern...]]></description>
  <pubDate>Sat, 05 Sep 2026 11:49:57 +0000</pubDate>
  <lastBuildDate>Wed, 21 Nov 2007 21:57:59 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=282</WebWizForums:feedURL>
   <title><![CDATA[Flange Issue - Flat pattern... : I have been having more issue...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=282&amp;PID=643&amp;title=flange-issue-flat-pattern#643</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2577">furian</a><br /><strong>Subject:</strong> 282<br /><strong>Posted:</strong> 21.Nov.2007 at 21:57<br /><br />I have been having more issue with flat pattern since I updated to SP3. I have found most of the issues to be with common sense mistakes. If the material can not do it in reality, you should not do it in Cad. <DIV>&nbsp;</DIV><DIV>The problem I am having now, is that what I have design works perfectly in reality, and in the exact same part just 14 inches shorter has no issues in Cad. I am getting material warp in Flat Pattern on this part. Can any one that is familiar with patterns take a look and see if you can see why it is doing this. ( I will have to edit the post once I get home since I can not send data from work to external FTP sites. I will then post a Link.)</DIV><DIV>&nbsp;</DIV><DIV>** Small 3" flanges Flat pattern correctly, One side of the 48" flange Flat Patterns Correctly. The other side warps the material and does not Flat pattern out.**</DIV>]]>
   <pubDate>Wed, 21 Nov 2007 21:57:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=282&amp;PID=643&amp;title=flange-issue-flat-pattern#643</guid>
