  <title>CAD Forum discussion (EN) : convert  2D to 3D</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : convert  2D to 3D]]></description>
  <pubDate>Fri, 28 Aug 2026 02:35:27 +0000</pubDate>
  <lastBuildDate>Mon, 30 Jun 2008 09:20:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=283</WebWizForums:feedURL>
   <title><![CDATA[convert  2D to 3D : The HEXACAD is a complete CAD...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=2225&amp;title=convert-2d-to-3d#2225</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=13561">hexagon2008</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 30.Jun.2008 at 09:20<br /><br />The HEXACAD is a complete CAD Software with features like 3D Modeling,database connectivity, built in Script support, customized reportgeneration, walk through creation, animation, voice enabled interactivedemo creation and many more. This software is compatible with AutoCADdxf (Drawing Exchange Format) files and up to dwg 2000 file format.Currently hexacad is available on the site with HVAC vertical.Application is developed in VC++ using technologies like OpenGL, ODBC,SAPI, internet, automation etc. <br><br><b>Features of the system</b><br><br><b>3D Modeling:</b> The System supports 3D Modeling representationof any three-dimensional object (either inanimate or living) .<br><br><b>Data Base Connectivity:</b> Records are stored in Data Bases.<br><br><b>Scripting Support:</b> Providing Built in Support for any time of Scripting. <br><br><b>Customized report generation:</b> All Formatted Report is generated.<br><br><b>Animation:</b> System supports Animation provide better looks. <br><br><b>Voice enabled interaction:</b> System Provide Voice Interaction for Demo for Presentation. <br><br><b>Compatibility:</b> Compatible with various format including Dxf and dwg          	           2000 file format.<br>]]>
   <pubDate>Mon, 30 Jun 2008 09:20:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=2225&amp;title=convert-2d-to-3d#2225</guid>
   <title><![CDATA[convert  2D to 3D : Hi tariqGeneraly in Autocad convert...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=2224&amp;title=convert-2d-to-3d#2224</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=13561">hexagon2008</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 30.Jun.2008 at 09:06<br /><br />Hi <font face="Tahoma, Arial, Sans serif">tariq<br><br>Generaly in Autocad convert 3d object in to 2d. your query is unique. any way you use following product <br><br>http://www.hexacad.com/download.php<br><br><br>form<br>Hexagon<br><br><br></font>]]>
   <pubDate>Mon, 30 Jun 2008 09:06:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=2224&amp;title=convert-2d-to-3d#2224</guid>
   <title><![CDATA[convert  2D to 3D : Thanks Malik-Noor ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=1022&amp;title=convert-2d-to-3d#1022</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 29.Jan.2008 at 11:43<br /><br /><FONT color=#ff0000><strong>Thanks Malik-Noor</strong> </FONT>]]>
   <pubDate>Tue, 29 Jan 2008 11:43:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=1022&amp;title=convert-2d-to-3d#1022</guid>
   <title><![CDATA[convert  2D to 3D : TYPE EXT IN THE COMMAND BOX SELECT...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=1000&amp;title=convert-2d-to-3d#1000</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=4360">MALIK-NOOR</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 27.Jan.2008 at 07:36<br /><br />TYPE&nbsp;&nbsp; EXT IN THE COMMAND BOX<DIV>SELECT THE OBJECT YOU WANT TO CONVERT 2D INTO 3D</DIV><DIV>GIVE THE HIGHT TO&nbsp; DESIRED </DIV><DIV>PRESS ENTER.</DIV><DIV>GIVE THE ANGLE IF YOU NEED OR LEAVE IT . AND PRESS ENTER </DIV><DIV>GO TO VIEW MENUE</DIV><DIV>CLICK ON VIEWPORTS AND THEN CLICK ON EITHER (SW, WE, NS ETC)</DIV><DIV>THIS THIS HOW YOU CONVERT 2D TO 3D .</DIV>]]>
   <pubDate>Sun, 27 Jan 2008 07:36:25 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=1000&amp;title=convert-2d-to-3d#1000</guid>
   <title><![CDATA[convert  2D to 3D : thanks but this tip isany other...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=648&amp;title=convert-2d-to-3d#648</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 22.Nov.2007 at 08:31<br /><br />thanks but this tip is&nbsp;any other language]]>
   <pubDate>Thu, 22 Nov 2007 08:31:01 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=648&amp;title=convert-2d-to-3d#648</guid>
   <title><![CDATA[convert  2D to 3D : You mean you have contours placed...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=647&amp;title=convert-2d-to-3d#647</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 22.Nov.2007 at 08:20<br /><br />You mean you have contours placed in 2D only (Z=0) and you want to elevate them to their altitudes? The CHELEV Lisp utility may help you in this case - see the tip:<DIV><a href="http://www.cadforum.cz/cadforum/qaID.asp?tip=5791" target="_blank">http://www.cadforum.cz/cadforum/qaID.asp?tip=5791</A></DIV><DIV>(in Czech but the sample DWG and CHELEV.LSP is there)</DIV>]]>
   <pubDate>Thu, 22 Nov 2007 08:20:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=647&amp;title=convert-2d-to-3d#647</guid>
   <title><![CDATA[convert  2D to 3D : I am working on contours i have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=646&amp;title=convert-2d-to-3d#646</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1984">tariq</a><br /><strong>Subject:</strong> 283<br /><strong>Posted:</strong> 22.Nov.2007 at 07:53<br /><br /><strong><FONT color=#cc0000>I<FONT face="Courier New, Courier, mono" size=3> am working on contours i have x,y value i want to convert in 3D How i convert 2D to 3D without wastage of time please help me Thanks.</FONT></FONT></strong>]]>
   <pubDate>Thu, 22 Nov 2007 07:53:16 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=283&amp;PID=646&amp;title=convert-2d-to-3d#646</guid>
