  <title>CAD Forum discussion (EN) : lt 2006 Hatch Issue</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : lt 2006 Hatch Issue]]></description>
  <pubDate>Tue, 03 Nov 2026 02:11:44 +0000</pubDate>
  <lastBuildDate>Wed, 16 Dec 2009 08:33:36 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2857</WebWizForums:feedURL>
   <title><![CDATA[lt 2006 Hatch Issue : yes - if i re-create the area...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2857&amp;PID=7679&amp;title=lt-2006-hatch-issue#7679</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=85197">ennerji</a><br /><strong>Subject:</strong> 2857<br /><strong>Posted:</strong> 16.Dec.2009 at 08:33<br /><br />yes - if i re-create the area with a new polyline and move it away&nbsp;i can hatch the new area.. Which does give me a "cheat" to complete the drawing thanks. ]]>
   <pubDate>Wed, 16 Dec 2009 08:33:36 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2857&amp;PID=7679&amp;title=lt-2006-hatch-issue#7679</guid>
   <title><![CDATA[lt 2006 Hatch Issue : can you create a polyline round...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2857&amp;PID=7674&amp;title=lt-2006-hatch-issue#7674</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=85972">thegodian</a><br /><strong>Subject:</strong> 2857<br /><strong>Posted:</strong> 15.Dec.2009 at 18:13<br /><br />can you create a polyline round the area to be hatched, move the polyline away from the main drawing, hatch inside the polyline&nbsp; then move it back to where it should be<DIV>&nbsp;</DIV><DIV>IG</DIV>]]>
   <pubDate>Tue, 15 Dec 2009 18:13:03 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2857&amp;PID=7674&amp;title=lt-2006-hatch-issue#7674</guid>
   <title><![CDATA[lt 2006 Hatch Issue : i am just finishing off a drwing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2857&amp;PID=7632&amp;title=lt-2006-hatch-issue#7632</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=85197">ennerji</a><br /><strong>Subject:</strong> 2857<br /><strong>Posted:</strong> 11.Dec.2009 at 18:31<br /><br />i am just finishing off a drwing with some hatching and have come up agaist a problem. When i select the area i want to hatch i get a&nbsp;box come up saying "Do&nbsp;you really want to do this?" I can only select no and as a result can't hatch. i have tried different hatches, tried hatching different area etc but to no avail. hatching has worked fine on previous drawings and still does - just one drawing file seems to be affected. <BR><BR>when i started the drawing it was on a laptop being saved to a usb stick. at this point hatches worked. i have since opened the file on a desktop and did a save as to the hard drive - it may be un related but it seems since then that the hatch command will not work. any help would be greatly appreciated as i need to get the drawing finished!!]]>
   <pubDate>Fri, 11 Dec 2009 18:31:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2857&amp;PID=7632&amp;title=lt-2006-hatch-issue#7632</guid>
