  <title>CAD Forum discussion (EN) : Error installing AutoCAD 2010 Trial</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Error installing AutoCAD 2010 Trial]]></description>
  <pubDate>Mon, 19 Oct 2026 18:37:21 +0000</pubDate>
  <lastBuildDate>Fri, 08 Jan 2010 03:59:53 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=2966</WebWizForums:feedURL>
   <title><![CDATA[Error installing AutoCAD 2010 Trial : I&amp;#039;ve tried installing .net...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2966&amp;PID=7906&amp;title=error-installing-autocad-2010-trial#7906</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=88885">tmc5</a><br /><strong>Subject:</strong> 2966<br /><strong>Posted:</strong> 08.Jan.2010 at 03:59<br /><br />I've tried installing .net 3.5 from microsoft and the installer will not run...&nbsp; .net 3.5.1 is already installed on my computer. I also do not have the AutoCAD dvd because I', downloading the trial from the Autodesk website.]]>
   <pubDate>Fri, 08 Jan 2010 03:59:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2966&amp;PID=7906&amp;title=error-installing-autocad-2010-trial#7906</guid>
   <title><![CDATA[Error installing AutoCAD 2010 Trial :    tmc5 wrote:Hi, I have a computer...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2966&amp;PID=7890&amp;title=error-installing-autocad-2010-trial#7890</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=2361">Arben.Allaraj</a><br /><strong>Subject:</strong> 2966<br /><strong>Posted:</strong> 07.Jan.2010 at 11:19<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by tmc5" alt="Originally posted by tmc5" style="vertical-align: text-bottom;" /> <strong>tmc5 wrote:</strong><br /><br />Hi, <br><br>I have a computer running windows 7 (x64) and I am in the process of installing the 2010 AutoCAD Trial.<br>Installation seems to run smoothly until it is finished with Direct x 9 and moves onto the next stage. I get a error message:<br>".NET 3.5 is not installed. AutoCAD 2010 cannot be installed without this component. See your system administrator for more information."<br><br>I am trying to install the 64 bit version of cad, so its not a matter of me trying to install the wrong version for my system.<br><br>I tried installing .net 3.5, but it wasn't doing anything, so I googled around and found that 3.5.1 is actually already installed on my computer, and yes, there is a check beside it in Turn Windows Features On or Off (I also found a link to a hotfix that seemed like it might have helped me, but its a corrupt file so I can't use it!)<br><br>&nbsp;<br><br>I am completely stumped. Please help! <br></td></tr></table><br><br>So try to install Micosoft.NET 3.5 download from microsoft or from AutoCAD DVD.<br>&nbsp;<br>]]>
   <pubDate>Thu, 07 Jan 2010 11:19:53 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2966&amp;PID=7890&amp;title=error-installing-autocad-2010-trial#7890</guid>
   <title><![CDATA[Error installing AutoCAD 2010 Trial : Hi, I have a computer running...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2966&amp;PID=7884&amp;title=error-installing-autocad-2010-trial#7884</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=88885">tmc5</a><br /><strong>Subject:</strong> 2966<br /><strong>Posted:</strong> 07.Jan.2010 at 05:26<br /><br />Hi, <br><br>I have a computer running windows 7 (x64) and I am in the process of installing the 2010 AutoCAD Trial.<br>Installation seems to run smoothly until it is finished with Direct x 9 and moves onto the next stage. I get a error message:<br>".NET 3.5 is not installed. AutoCAD 2010 cannot be installed without this component. See your system administrator for more information."<br><br>I am trying to install the 64 bit version of cad, so its not a matter of me trying to install the wrong version for my system.<br><br>I tried installing .net 3.5, but it wasn't doing anything, so I googled around and found that 3.5.1 is actually already installed on my computer, and yes, there is a check beside it in Turn Windows Features On or Off (I also found a link to a hotfix that seemed like it might have helped me, but its a corrupt file so I can't use it!)<br><br>I am completely stumped. Please help! <br>]]>
   <pubDate>Thu, 07 Jan 2010 05:26:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=2966&amp;PID=7884&amp;title=error-installing-autocad-2010-trial#7884</guid>
