  <title>CAD Forum discussion (EN) : Measure Command: Random Block Alignment</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Measure Command: Random Block Alignment]]></description>
  <pubDate>Sat, 05 Sep 2026 05:07:00 +0000</pubDate>
  <lastBuildDate>Wed, 13 Jan 2010 23:12:46 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3008</WebWizForums:feedURL>
   <title><![CDATA[Measure Command: Random Block Alignment : Nothing like the measure command...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3008&amp;PID=7989&amp;title=measure-command-random-block-alignment#7989</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 3008<br /><strong>Posted:</strong> 13.Jan.2010 at 23:12<br /><br />Nothing like the measure command that is that flexible..&nbsp; You could run the measure command separately for each block, for each spacing/distance from beginning of the curve, and erase the "extra" copies.]]>
   <pubDate>Wed, 13 Jan 2010 23:12:46 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3008&amp;PID=7989&amp;title=measure-command-random-block-alignment#7989</guid>
   <title><![CDATA[Measure Command: Random Block Alignment : Hello,Working on aligning a series...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3008&amp;PID=7988&amp;title=measure-command-random-block-alignment#7988</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=90261">lstecyk</a><br /><strong>Subject:</strong> 3008<br /><strong>Posted:</strong> 13.Jan.2010 at 22:44<br /><br />Hello,<br><br>Working on aligning a series of variably sized rectabgular blocks along a curve.&nbsp; Is there a way to use the measure tool or some scripting to align a few different blocks along the same curve?<br><br>the blocks varying in size between 4" x 36" to 4" x 60"<br><br>thanks!<br><br>]]>
   <pubDate>Wed, 13 Jan 2010 22:44:20 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3008&amp;PID=7988&amp;title=measure-command-random-block-alignment#7988</guid>
