  <title>CAD Forum discussion (EN) : Windows errors</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Windows errors]]></description>
  <pubDate>Wed, 21 Oct 2026 14:27:54 +0000</pubDate>
  <lastBuildDate>Sun, 17 Jan 2010 18:03:13 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3026</WebWizForums:feedURL>
   <title><![CDATA[Windows errors :   Tankman wrote:Are all updates...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3026&amp;PID=8057&amp;title=windows-errors#8057</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=90794">Callum</a><br /><strong>Subject:</strong> 3026<br /><strong>Posted:</strong> 17.Jan.2010 at 18:03<br /><br /> <table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Tankman" alt="Originally posted by Tankman" style="vertical-align: text-bottom;" /> <strong>Tankman wrote:</strong><br /><br /><p>Are all updates for Vista, your OS, up to date?</p><br /><div>I use an external HDD for backups however, my OS is Windows XP Pro SP3.</div><br /><div> </div><br /><div>Never had the problem you describe above.</div></td></tr></table> <br /><br />You're lucky if you use XP instead of XP is much better Vista.<br />My Vista however is fully updated.<br />meanwhile thanks the same.<br />Bye]]>
   <pubDate>Sun, 17 Jan 2010 18:03:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3026&amp;PID=8057&amp;title=windows-errors#8057</guid>
   <title><![CDATA[Windows errors : Are all updates for Vista, your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3026&amp;PID=8054&amp;title=windows-errors#8054</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=82126">Tankman</a><br /><strong>Subject:</strong> 3026<br /><strong>Posted:</strong> 17.Jan.2010 at 14:25<br /><br /><P>Are all updates for Vista, your OS, up to date?</P><DIV>I use an external HDD for backups however, my OS is Windows XP Pro SP3.</DIV><DIV>&nbsp;</DIV><DIV>Never had the problem you describe above.</DIV>]]>
   <pubDate>Sun, 17 Jan 2010 14:25:11 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3026&amp;PID=8054&amp;title=windows-errors#8054</guid>
   <title><![CDATA[Windows errors : I all,  I have a problem on my...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3026&amp;PID=8045&amp;title=windows-errors#8045</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=90794">Callum</a><br /><strong>Subject:</strong> 3026<br /><strong>Posted:</strong> 16.Jan.2010 at 21:43<br /><br />I all, <br />I have a problem on my Windows Vista that began afetr the purchase of an external Hard Disk Freecom. <br />A few days afetr the purchase I disconnected it while it was writing and, since that moment, every time I connect and disconnect it, the PC go to freeze mode for 5 minutes. <br />The same thing happen even if the hard disk is disconnected: every time I start windows it go to freeze a little after the password, and every time I connect and disconnect a usb device. <br />I have looked for the solution everywhere, updated windows, unistalled and installed the hard disk from the device manager but I solved the problem only when I restored a recent backup. <br />Yesterday the Hard disk was writing a backup while Vista was installing the updates; at the end of the proceure windows restarted automatically and the problem began again!!! <br />The Pc go to freeze when it starts, every time I connect or disconnect the hard disk, an usb earphone that has always worked switch on but there is no audio and I don't know how many others usb devices will have problems. <br />Has anyone an idea to solve this problem before I throw out of the window Vista or the the hard disk? <br />Thank you <br /><br /><br />__________________<br />Never seen <a href="http://www.giftideashop.net/gift-girl.html" target="_blank" rel="nofollow">gift for girl</a> like these! (<a href="http://www.idee-regalo.biz/regali-natale.html" target="_blank" rel="nofollow">regali aziendali natale</a> on italian or <a href="http://www.ideescadeauxoriginaux.com/" target="_blank" rel="nofollow">idée cadeau</a> on french), <a href="http://www.fotomatrim&#111;nio.biz/fotografo.html" target="_blank" rel="nofollow">fotografo</a>]]>
   <pubDate>Sat, 16 Jan 2010 21:43:23 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3026&amp;PID=8045&amp;title=windows-errors#8045</guid>
