  <title>CAD Forum discussion (EN) : Acad Versions</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : Acad Versions]]></description>
  <pubDate>Mon, 28 Sep 2026 11:39:03 +0000</pubDate>
  <lastBuildDate>Fri, 29 Jan 2010 18:40:57 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3105</WebWizForums:feedURL>
   <title><![CDATA[Acad Versions : Although I use &amp;#039;05 and &amp;#039;07,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8280&amp;title=acad-versions#8280</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=82126">Tankman</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 18:40<br /><br />Although I use '05 and '07, I always save to AutoCAD 2000.<DIV>&nbsp;</DIV><DIV>This is at the request of <U>many</U> of my clients.</DIV><DIV>&nbsp;</DIV><DIV>I also post here in 2000 so I avoid problems.</DIV><DIV>'05 is on my laptop, '07 is on my desktop work station.&nbsp; <img src="http://www.cadforum.cz/forum_en/smileys/smiley1.gif" height="17" width="17" border="0" align="absmiddle" alt="Smile" /></DIV><DIV>&nbsp;</DIV><DIV>I have asked clients using other CAD programs to save as a *.dwg file for email. I see a lot of junque that I have to clean up when I open their files; i.e.: fonts, dimensions, all kinds of "stuff." Some companies are just set in their ways and don't want to change to AutoDesk products.</DIV>]]>
   <pubDate>Fri, 29 Jan 2010 18:40:57 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8280&amp;title=acad-versions#8280</guid>
   <title><![CDATA[Acad Versions : I would suggest that whoever your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8279&amp;title=acad-versions#8279</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=61756">tulip3D</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 16:20<br /><br />I would suggest that whoever your getting those 07 and 09 files just tell the fool giving them to you to downgrade them to R12.DXF. Problem solved. No downloading.<DIV>You might even be able to open dxf's in Drafix, but im not familiar with that program.</DIV>]]>
   <pubDate>Fri, 29 Jan 2010 16:20:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8279&amp;title=acad-versions#8279</guid>
   <title><![CDATA[Acad Versions : Regarding changing color of objects-Go...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8275&amp;title=acad-versions#8275</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 06:09<br /><br />Regarding changing color of objects-<br>Go into the layer manager ("layer" command), change color of layers. If objects have a set color rather than "bylayer", then you'd have to change their color using the "chprop" command. <br><br>Don't know why you're having installation problems.<br>]]>
   <pubDate>Fri, 29 Jan 2010 06:09:19 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8275&amp;title=acad-versions#8275</guid>
   <title><![CDATA[Acad Versions : Yeah, I have tried to install...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8274&amp;title=acad-versions#8274</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=93174">Richardatf</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 05:05<br /><br />Yeah, I have tried to install that link before.&nbsp; I can download it, but the installation always hits a dead end.&nbsp; A screen comes up that asks what to install, I check the DWG TrueView (only one available), then it does nothing, no tab to continue on. &nbsp;&nbsp; Very frustrating.]]>
   <pubDate>Fri, 29 Jan 2010 05:05:18 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8274&amp;title=acad-versions#8274</guid>
   <title><![CDATA[Acad Versions : Thanks for the link.   I will...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8273&amp;title=acad-versions#8273</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=93174">Richardatf</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 05:01<br /><br />Thanks for the link. &nbsp; &nbsp; I will save drawings in Drafix, and when I open them in Autocad, they are so dark I can barely see them on the screen.&nbsp;&nbsp; I am a novice at all this stuff, perhaps you can tell me, how can I copy items and paste them in a different color? &nbsp;&nbsp; Or how can I select all items of one color and change them to another? &nbsp;&nbsp; Any help is greatly appreciated. &nbsp; Thanks again for the link, will try it now.]]>
   <pubDate>Fri, 29 Jan 2010 05:01:13 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8273&amp;title=acad-versions#8273</guid>
   <title><![CDATA[Acad Versions : No problem downloading, but problem...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8272&amp;title=acad-versions#8272</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 03:53<br /><br />No problem downloading, but problem opening them in 2000 version :)<DIV>newer versions can be converted to older, free Autodesk download:</DIV><DIV><a href="http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&siteID=123112" target="_blank" rel="nofollow">http://usa.autodesk.com/adsk/servlet/pc/index?id=6703438&amp;siteID=123112</A></DIV><DIV>&nbsp;</DIV><DIV>Don't knpw about Drafix, but most likely will need to fix them from Drafix when exporting to dxf(?).&nbsp; What sort of problems?</DIV>]]>
   <pubDate>Fri, 29 Jan 2010 03:53:10 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8272&amp;title=acad-versions#8272</guid>
   <title><![CDATA[Acad Versions : I have AutoCad2000, and would...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8271&amp;title=acad-versions#8271</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=93174">Richardatf</a><br /><strong>Subject:</strong> 3105<br /><strong>Posted:</strong> 29.Jan.2010 at 03:08<br /><br />&nbsp;&nbsp; I have AutoCad2000, and would like to be able to download Acad2007 and 2009 Drawings in DWG format.&nbsp; Is this possible?&nbsp; If so, what do I need to accomplish it?<br><br>&nbsp;&nbsp; On an aside, I also have an old version of Drafix Cad, which I like very much.&nbsp; I can save drawings in AutoCad format, but when I open them in Autocad there are problems.&nbsp;&nbsp; Any one recommend a utility to open Drafix drawings in Autocad2000?<br>]]>
   <pubDate>Fri, 29 Jan 2010 03:08:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3105&amp;PID=8271&amp;title=acad-versions#8271</guid>
