  <title>CAD Forum discussion (EN) : Import dgn to dwg</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Civil 3D, Map, InfraWorks : Import dgn to dwg]]></description>
  <pubDate>Wed, 30 Sep 2026 09:56:46 +0000</pubDate>
  <lastBuildDate>Thu, 29 Apr 2010 11:46:21 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3138</WebWizForums:feedURL>
   <title><![CDATA[Import dgn to dwg :  We at Dimension India(www.dimensionicad.com)...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3138&amp;PID=9619&amp;title=import-dgn-to-dwg#9619</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=113903">Rajashree</a><br /><strong>Subject:</strong> 3138<br /><strong>Posted:</strong> 29.Apr.2010 at 11:46<br /><br />We at Dimension India(www.dimensionicad.com) use the following method to import dgn to dwg in Autocad:<br><br>To         optimize the data transfer from the MicroStation® DGN file format, the creator of the MicroStation drawings should consider the following recommendations:            <!--UList--><span><a name="WS1a9193826455f5ff1f238a510d5d194df1-7fa5"></a></span><ul><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81ce9"></a></span>Create a separate DGN file for each design            model         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cea"></a></span>Do not reference sheet models from design            models         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81ceb"></a></span>Minimize the use of custom objects and            other data unique to MicroStation         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cec"></a></span>Use ByLevel for color, line style, and            weight properties         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81ced"></a></span>Use simple line styles as much as possible         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cee"></a></span>Use simple patterns and pattern styles         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cef"></a></span>Use TrueType text fonts rather than SHX            text fonts         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cf0"></a></span>Use defined styles for dimensions and            text rather than a “none” style         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cf1"></a></span>Use simple dimension styles if possible         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cf2"></a></span>Use shared cells as opposed to normal            (library) cells         </li><li><span><a name="WS1a9193826455f5ff-2ade9d9118a20d4f81cf3"></a></span>Work primarily in one format, DWG or            DGN, rather than switching back and forth         </li></ul>      <p><span><a name="WS73099cc142f487551dc3623711da7b58889-6ffc"></a></span>When         importing a DGN file, specify the conversion units (master units         or sub-units) based on the DWG file's drawing units. For example,         if you receive a DGN file with master units set to meters, and sub-units         set to millimeters, and you need the drawing units of the DWG file         to be in meters, then select master units in the Import DGN Settings         dialog box. This matches the meters in the DGN file to the meters         in the DWG file. <br></p><p>I hope this will help u as well.</p><p>Thanks!!<br></p><br><span style="font-size:10px"><br /><br />Edited by Rajashree - 29.Apr.2010 at 11:47</span>]]>
   <pubDate>Thu, 29 Apr 2010 11:46:21 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3138&amp;PID=9619&amp;title=import-dgn-to-dwg#9619</guid>
   <title><![CDATA[Import dgn to dwg : Bentley havent all solutions for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3138&amp;PID=9338&amp;title=import-dgn-to-dwg#9338</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=108717">Boris_t</a><br /><strong>Subject:</strong> 3138<br /><strong>Posted:</strong> 08.Apr.2010 at 01:15<br /><br />Bentley havent all solutions for atributs into geometry. <DIV>XYZ in Auto CAD was atrubuts attach onto geometry, thats automatical design.</DIV><DIV>So, if you'd like to take out all&nbsp;points ( with xyz )&nbsp;from MSBentley, best way is make&nbsp;a import dgn, and read atributes ( xyz ) like text into&nbsp;coordinates.</DIV><DIV>Query&nbsp;tehnic:</DIV><DIV><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: 'Arial Narrow'; mso-bidi-font-family: Arial"><FONT size=3><FONT color=#000000>Using numerical text values with a text object at zero elevation to create a surface <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></FONT></SPAN></B></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>Publish date: Apr-12-2006<o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000><o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>Applies to: <o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>AutoCAD Civil 3D 2005 <o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>AutoCAD Civil 3D 2006 <o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>AutoCAD Civil 3D 2009 <o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000><SPAN style="mso-spacerun: yes">&nbsp;</SPAN><o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>Issue<o:p></o:p></FONT></SPAN></B></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><o:p><FONT color=#000000>&nbsp;</FONT></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>You placed AutoCAD text objects in a drawing. These objects are numbers that represent elevations. For example, an AutoCAD text object has a value of 256.4, but the properties of the text object show a Position Z value of zero. You want to move each text object to the elevation provided by its text value in order to create a surface.<o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><o:p><FONT color=#000000>&nbsp;</FONT></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><B style="mso-bidi-font-weight: normal"><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>Technical Solutions <o:p></o:p></FONT></SPAN></B></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><o:p><FONT color=#000000>&nbsp;</FONT></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>To move each text object to its text value elevation, follow these steps:<o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><o:p><FONT color=#000000>&nbsp;</FONT></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>Note: In the original drawing, make sure that the text is alone on one layer. You should also make a note of the layer name.<o:p></o:p></FONT></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><o:p><FONT color=#000000>&nbsp;</FONT></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt" =Ms&#111;normal><U><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt"><FONT color=#000000>To attach the drawing<o:p></o:p></FONT></SPAN></U></P><OL =1><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo1; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Open a New drawing <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo1; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">On the Map menu,&nbsp;click&nbsp;Drawings &gt; Define/Modify Drawing Set. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo1; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">In the Define/Modify Drawing Set dialog box, click Attach. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo1; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">In the Attach dialog box, browse to the drawing with the text. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo1; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Add. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l2 level1 lfo1; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click OK to close each dialog box. <o:p></o:p></SPAN></LI></OL><P><U><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt">To define a query</SPAN></U><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><OL =1><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">On the Map menu, click Query &gt; Define Query. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Property. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Select the Layer option (you choose the layer to use). <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Values. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Select the layer containing the text. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click OK to close each dialog box. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Property. <o:p></o:p></SPAN></LI></OL><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><P style="MARGIN: 0cm 0cm 0pt 18pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><OL =1 start=8><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Select&nbsp;the Object Type option (you choose all text on that layer). <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Values. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Select the Text. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click OK to close each dialog box. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">In the Query Mode area, select the Draw option. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">In the Options area, select the Alter Properties option. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">In the Select Property area,&nbsp;select the Elevation option. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Expression. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Expand the Properties folder and&nbsp;select STRING, and&nbsp;then click OK. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l0 level1 lfo2; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Add, and then click OK.<o:p></o:p></SPAN></LI></OL><P><U><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt">Execute the Query</SPAN></U><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><OL =1><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l3 level1 lfo3; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click Execute Query. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l3 level1 lfo3; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Click OK . <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l3 level1 lfo3; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Zoom Extents.<o:p></o:p></SPAN></LI></OL><P><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt">Each text object in the drawing now has the physical z value equal to the text value. For example, a text object seen as 254.6 has a Z (height) property of 254.6.<o:p></o:p></SPAN></P><P><U><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt">Create a surface from text objects</SPAN></U><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt"><o:p></o:p></SPAN></P><OL =1><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l1 level1 lfo4; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Create a surface with a name. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l1 level1 lfo4; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Expand the Definition category. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l1 level1 lfo4; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">Right-click on Drawing Objects. Click Add. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; COLOR: #232323; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l1 level1 lfo4; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; FONT-SIZE: 10pt">On the Object Type drop-down menu, select Text. <o:p></o:p></SPAN></LI><LI style="MARGIN: 0cm 0cm 0pt; mso-margin-top-alt: auto; mso-margin-bottom-alt: auto; mso-list: l1 level1 lfo4; tab-stops: list 36.0pt" =Ms&#111;normal><SPAN style="FONT-FAMILY: Arial; COLOR: #232323; FONT-SIZE: 10pt">Select all the text in the drawing.</SPAN></LI></OL></DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Thu, 08 Apr 2010 01:15:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3138&amp;PID=9338&amp;title=import-dgn-to-dwg#9338</guid>
   <title><![CDATA[Import dgn to dwg : In Auotcad map 2009we are using...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3138&amp;PID=8357&amp;title=import-dgn-to-dwg#8357</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=94462">jite</a><br /><strong>Subject:</strong> 3138<br /><strong>Posted:</strong> 05.Feb.2010 at 06:03<br /><br />In Auotcad map 2009&nbsp;we are using import&nbsp; facility of dgn to dwg then loading of dgn 3dpolyline in autocad then only elevation is display but in microstation there is a different z value like 1.32,1.29,2.00 so in autocad only elevation is displayed, does&nbsp;not show all z vaule in some element . ]]>
   <pubDate>Fri, 05 Feb 2010 06:03:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3138&amp;PID=8357&amp;title=import-dgn-to-dwg#8357</guid>
