  <title>CAD Forum discussion (EN) : Mexplode.vlx</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : ARKANCE (CAD Studio) applications : Mexplode.vlx]]></description>
  <pubDate>Tue, 03 Nov 2026 03:11:54 +0000</pubDate>
  <lastBuildDate>Thu, 18 Mar 2010 15:48:48 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3147</WebWizForums:feedURL>
   <title><![CDATA[Mexplode.vlx :    Vladimir Michl wrote:What...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8977&amp;title=mexplodevlx#8977</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=104096">Kelly L</a><br /><strong>Subject:</strong> 3147<br /><strong>Posted:</strong> 18.Mar.2010 at 15:48<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by Vladimir Michl" alt="Originally posted by Vladimir Michl" style="vertical-align: text-bottom;" /> <strong>Vladimir Michl wrote:</strong><br /><br />What is MExplode? This is not a Xanadu application.<div></div><div></div><div>&nbsp;</div><div>Any VLX file is active only in the session/drawing it was loaded in (unless it was added to any <em>autoload</em> mechanism - ACAD.LSP, ACADDOC.LSP, ACAD.MNL or the Startup Suite in the APPLOAD command).</div></td></tr></table><br>Thank you for the post. <br>Hi guys, Im a newbie. Nice to join this forum.<br><br>]]>
   <pubDate>Thu, 18 Mar 2010 15:48:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8977&amp;title=mexplodevlx#8977</guid>
   <title><![CDATA[Mexplode.vlx : That&amp;#039;s right &amp;#034;ExplodeM&amp;#034;Sorry...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8394&amp;title=mexplodevlx#8394</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=95387">mano1sa</a><br /><strong>Subject:</strong> 3147<br /><strong>Posted:</strong> 08.Feb.2010 at 10:37<br /><br />That's right&nbsp;&nbsp; "ExplodeM"<br>Sorry for mistake, but there is nothing in briefcase in the APPLOAD command.]]>
   <pubDate>Mon, 08 Feb 2010 10:37:33 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8394&amp;title=mexplodevlx#8394</guid>
   <title><![CDATA[Mexplode.vlx : If you mean the &amp;#034;ExplodeM&amp;#034;...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8393&amp;title=mexplodevlx#8393</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 3147<br /><strong>Posted:</strong> 08.Feb.2010 at 09:05<br /><br />If you mean the "ExplodeM" utility, it does not write any file. Generally - the most usual autoload method is the briefcase in the APPLOAD command - so please check this first.]]>
   <pubDate>Mon, 08 Feb 2010 09:05:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8393&amp;title=mexplodevlx#8393</guid>
   <title><![CDATA[Mexplode.vlx : Thanks for reply. Mexplode.vlx...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8392&amp;title=mexplodevlx#8392</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=95387">mano1sa</a><br /><strong>Subject:</strong> 3147<br /><strong>Posted:</strong> 08.Feb.2010 at 08:56<br /><br />Thanks for reply.<br>Mexplode.vlx&nbsp; is a Cad utilities which can be found on the same site.<br>If you want to see, go on downloads and find through search.<br>I used Appload command.<br>Should I remove the file acad2008doc or any other file which is doing the<br>automation. <br>]]>
   <pubDate>Mon, 08 Feb 2010 08:56:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8392&amp;title=mexplodevlx#8392</guid>
   <title><![CDATA[Mexplode.vlx : What is MExplode? This is not...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8387&amp;title=mexplodevlx#8387</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 3147<br /><strong>Posted:</strong> 07.Feb.2010 at 21:54<br /><br />What is MExplode? This is not a Xanadu application.<DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>Any VLX file is active only in the session/drawing it was loaded in (unless it was added to any <EM>autoload</EM> mechanism - ACAD.LSP, ACADDOC.LSP, ACAD.MNL or the Startup Suite in the APPLOAD command).</DIV>]]>
   <pubDate>Sun, 07 Feb 2010 21:54:38 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8387&amp;title=mexplodevlx#8387</guid>
   <title><![CDATA[Mexplode.vlx : I loaded the Mexplode.vlx and...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8386&amp;title=mexplodevlx#8386</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=95387">mano1sa</a><br /><strong>Subject:</strong> 3147<br /><strong>Posted:</strong> 07.Feb.2010 at 19:08<br /><br />I loaded the Mexplode.vlx and now when I open any drawing a lisp file is written automatically.<br>I am using autocad2008. want to unload this application.<br>]]>
   <pubDate>Sun, 07 Feb 2010 19:08:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3147&amp;PID=8386&amp;title=mexplodevlx#8386</guid>
