  <title>CAD Forum discussion (EN) : Elliptical Heads For Pressure Vessels</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Elliptical Heads For Pressure Vessels]]></description>
  <pubDate>Sat, 05 Sep 2026 05:59:18 +0000</pubDate>
  <lastBuildDate>Sat, 20 Feb 2010 16:09:32 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3208</WebWizForums:feedURL>
   <title><![CDATA[Elliptical Heads For Pressure Vessels : That worked perfect thank you....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8562&amp;title=elliptical-heads-for-pressure-vessels#8562</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=74767">Castor63</a><br /><strong>Subject:</strong> 3208<br /><strong>Posted:</strong> 20.Feb.2010 at 16:09<br /><br />That worked perfect thank you. I wirked at trying to use elipses and just couldnt figure out why I couldnt join the lines to create a solid after wards. None the less you way did the job <img src="https://www.cadforum.cz/forum_en/smileys/smiley32.gif" border="0" align="middle" /> ]]>
   <pubDate>Sat, 20 Feb 2010 16:09:32 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8562&amp;title=elliptical-heads-for-pressure-vessels#8562</guid>
   <title><![CDATA[Elliptical Heads For Pressure Vessels :  Ok here is the file.  uplo...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8560&amp;title=elliptical-heads-for-pressure-vessels#8560</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=67971">KobusErasmus</a><br /><strong>Subject:</strong> 3208<br /><strong>Posted:</strong> 20.Feb.2010 at 11:53<br /><br /><a href="http://www.cadforum.cz/forum_en/uploads/20100220_115309_C&#111;nical_shape.dwg" target="_blank"><DIV>Ok here is the file.</DIV><DIV>&nbsp;</DIV><DIV>uploads/20100220_115309_Conical_shape.dwg</DIV></A>]]>
   <pubDate>Sat, 20 Feb 2010 11:53:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8560&amp;title=elliptical-heads-for-pressure-vessels#8560</guid>
   <title><![CDATA[Elliptical Heads For Pressure Vessels : Hi, Using Autocad 2010, I have...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8559&amp;title=elliptical-heads-for-pressure-vessels#8559</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=67971">KobusErasmus</a><br /><strong>Subject:</strong> 3208<br /><strong>Posted:</strong> 20.Feb.2010 at 11:51<br /><br />Hi,<DIV>Using Autocad 2010, I have done this attached file.&nbsp; Use the parametric commands.&nbsp; This profile can be expanded further and revolved to give you what you need.</DIV><DIV>&nbsp;</DIV><DIV>However if you do not have 2010, the profile can still be done using conventional draughting methods.&nbsp; Look at the drawing that I am attaching.</DIV><DIV>&nbsp;</DIV><DIV>1. I first set up the centre line of the vessel.</DIV><DIV>2. Using offset - dia / 2 - place the one outside line of the outer dia.</DIV><DIV>3. Draw a circle with the centre point on the vessel centre line and the radius being the crown radius.</DIV><DIV>&nbsp;</DIV><DIV>Now from here there are 2 routes to take:</DIV><DIV>First the long one:</DIV><DIV>4. Offset the outer dia line and the crown circle by the knuckle radius.</DIV><DIV>5. The intersection of these is now the centre point location for the knuckle arc - using that as reference draw a circle for the knuckle.</DIV><DIV>6. You now have the construction lines - using that draw the outline, offset to get the thickness, revolve, etc. and you have a 3d model.</DIV><DIV>&nbsp;</DIV><DIV>The quick and short way:</DIV><DIV>4. Using trim command, trim the crown circle so that only the bit remains between the vessel centre line and the outer dia line - see the drawing.</DIV><DIV>5. Using the fillet command with the radius set to the knuckle radius, fillet the crown arc and outer dia line.</DIV><DIV>6. From here if you have some 3d experience it should be easy to create a profile and revolve it into your vessel.</DIV><DIV>&nbsp;</DIV><DIV>Hope this helps, don't know if I understood your question correctly.&nbsp; Using ellipse and trimming it does not work, to create a 3d you need to join the lines into a polyline and ellipse does not join - even if you trim it.&nbsp; Its actually a pretty useless command and I very rarely use it.</DIV><DIV>&nbsp;</DIV><DIV>Ciao</DIV><DIV>Kobus</DIV><DIV>&nbsp;</DIV><DIV>PS. I have tried to upload the file but for some reason I get an access denied message.&nbsp; Mail me if you need help.</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Sat, 20 Feb 2010 11:51:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8559&amp;title=elliptical-heads-for-pressure-vessels#8559</guid>
   <title><![CDATA[Elliptical Heads For Pressure Vessels : yes I am making a solid 3D. I...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8538&amp;title=elliptical-heads-for-pressure-vessels#8538</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=74767">Castor63</a><br /><strong>Subject:</strong> 3208<br /><strong>Posted:</strong> 19.Feb.2010 at 04:38<br /><br />yes I am making a solid 3D. I am thinking I can make an elipse going from 1 quadrant of the shell to the other then give it a hieght, trim it down and do a revolve. Would that make it the same as using the knuckle radius though. Is the Inside crown radius, from the head base to the top center inside?<span style="font-size:10px"><br /><br />Edited by Castor63 - 19.Feb.2010 at 04:42</span>]]>
   <pubDate>Fri, 19 Feb 2010 04:38:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8538&amp;title=elliptical-heads-for-pressure-vessels#8538</guid>
   <title><![CDATA[Elliptical Heads For Pressure Vessels : Is this to be a 3d solid?  ]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8537&amp;title=elliptical-heads-for-pressure-vessels#8537</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 3208<br /><strong>Posted:</strong> 19.Feb.2010 at 04:32<br /><br />Is this to be a 3d solid?<DIV></DIV>]]>
   <pubDate>Fri, 19 Feb 2010 04:32:14 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8537&amp;title=elliptical-heads-for-pressure-vessels#8537</guid>
   <title><![CDATA[Elliptical Heads For Pressure Vessels : I am looking for the easiest way...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8536&amp;title=elliptical-heads-for-pressure-vessels#8536</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=74767">Castor63</a><br /><strong>Subject:</strong> 3208<br /><strong>Posted:</strong> 19.Feb.2010 at 02:31<br /><br />I am looking for the easiest way to create an elliptical head for a 3D pressure vessel. The outside Dia. is 103" and, inside crown radius is 93.16", inside knuckle radius of 17.79" and a thickness of 0.500" <img src="https://www.cadforum.cz/forum_en/smileys/smiley5.gif" border="0" align="middle" /> ]]>
   <pubDate>Fri, 19 Feb 2010 02:31:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3208&amp;PID=8536&amp;title=elliptical-heads-for-pressure-vessels#8536</guid>
