  <title>CAD Forum discussion (EN) : AutoCAD 2007 &amp; Microstation V8</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : CAD - general : AutoCAD 2007 &amp; Microstation V8]]></description>
  <pubDate>Fri, 06 Nov 2026 06:29:29 +0000</pubDate>
  <lastBuildDate>Mon, 06 Aug 2007 08:39:08 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=33</WebWizForums:feedURL>
   <title><![CDATA[AutoCAD 2007 &amp; Microstation V8 : Thank you... much appreciated...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=33&amp;PID=70&amp;title=autocad-2007-microstation-v8#70</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=135">WaterCorp</a><br /><strong>Subject:</strong> 33<br /><strong>Posted:</strong> 06.Aug.2007 at 08:39<br /><br />Thank you... much appreciated !!!]]>
   <pubDate>Mon, 06 Aug 2007 08:39:08 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=33&amp;PID=70&amp;title=autocad-2007-microstation-v8#70</guid>
   <title><![CDATA[AutoCAD 2007 &amp; Microstation V8 : There was a free Autodesk DGN...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=33&amp;PID=69&amp;title=autocad-2007-microstation-v8#69</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 33<br /><strong>Posted:</strong> 06.Aug.2007 at 08:37<br /><br />There was a free Autodesk DGN V8 plugin available for AutoCAD 2007 for a limited time. Now this functionality (DGN import/export + underlay) is available in AutoCAD 2008.<DIV>DGN format support is also available in AutoCAD Map (even in the older versions) - so either crossgrade to Map or upgrade to AutoCAD 2008.</DIV>]]>
   <pubDate>Mon, 06 Aug 2007 08:37:42 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=33&amp;PID=69&amp;title=autocad-2007-microstation-v8#69</guid>
   <title><![CDATA[AutoCAD 2007 &amp; Microstation V8 : Hi there, does anybody know if...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=33&amp;PID=68&amp;title=autocad-2007-microstation-v8#68</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=135">WaterCorp</a><br /><strong>Subject:</strong> 33<br /><strong>Posted:</strong> 06.Aug.2007 at 08:20<br /><br />Hi there,<DIV>does anybody know if it is possible to access dwg and dng files from their respective programs? Maybe I am not working this correctly.... I would like to work on Microstation V8 dgn drawings IN AutoCAD 2007 and then save them so that they can be opened and edited in Microstation V8 thereafter. Any help would be much appreciated.... ps new to this forum !!!</DIV>]]>
   <pubDate>Mon, 06 Aug 2007 08:20:30 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=33&amp;PID=68&amp;title=autocad-2007-microstation-v8#68</guid>
