  <title>CAD Forum discussion (EN) : Autocad LT 8 Dimensions</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Autocad LT 8 Dimensions]]></description>
  <pubDate>Fri, 04 Sep 2026 18:17:51 +0000</pubDate>
  <lastBuildDate>Tue, 06 Apr 2010 14:37:49 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3566</WebWizForums:feedURL>
   <title><![CDATA[Autocad LT 8 Dimensions : See the DIMLFAC variable or the...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3566&amp;PID=9300&amp;title=autocad-lt-8-dimensions#9300</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 3566<br /><strong>Posted:</strong> 06.Apr.2010 at 14:37<br /><br />See the &#091;VAR&#093;DIMLFAC&#091;/VAR&#093; variable or the Scale factor on the Primary units tab of the Dim styles dialog.]]>
   <pubDate>Tue, 06 Apr 2010 14:37:49 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3566&amp;PID=9300&amp;title=autocad-lt-8-dimensions#9300</guid>
   <title><![CDATA[Autocad LT 8 Dimensions : I have Autocad Lt 8 and I would...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3566&amp;PID=9299&amp;title=autocad-lt-8-dimensions#9299</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=108251">DJBlackwell</a><br /><strong>Subject:</strong> 3566<br /><strong>Posted:</strong> 06.Apr.2010 at 14:32<br /><br />I have Autocad Lt 8 and I would like to change the units from centimeters to millimeters. Eg; a line dimension is shown as 0.8 and I want it to display as 80.]]>
   <pubDate>Tue, 06 Apr 2010 14:32:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3566&amp;PID=9299&amp;title=autocad-lt-8-dimensions#9299</guid>
