  <title>CAD Forum discussion (EN) : Browse window  doesn&#039;t appear</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Browse window  doesn&#039;t appear]]></description>
  <pubDate>Mon, 19 Oct 2026 20:33:09 +0000</pubDate>
  <lastBuildDate>Wed, 21 Apr 2010 00:12:50 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3658</WebWizForums:feedURL>
   <title><![CDATA[Browse window  doesn&#039;t appear :   rsuarez wrote:You couldn&amp;#039;t...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9513&amp;title=browse-window-doesnt-appear#9513</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=82126">Tankman</a><br /><strong>Subject:</strong> 3658<br /><strong>Posted:</strong> 21.Apr.2010 at 00:12<br /><br /><table width="99%"><tr><td class="BBquote"><img src="forum_images/quote_box.png" title="Originally posted by rsuarez" alt="Originally posted by rsuarez" style="vertical-align: text-bottom;" /> <strong>rsuarez wrote:</strong><br /><br />You couldn't be more right, I changed it and it worked fine. I have no enough kind words to express my gratitude, I was becoming crazy with the thing. THANKS A LOT.</td></tr></table> <DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>When Cad64 speaks, we all listen. Thanks California!&nbsp; <img src="http://www.cadforum.cz/forum_en/smileys/smiley10.gif" height="17" width="17" border="0" align="absmiddle" alt="Star" /></DIV>]]>
   <pubDate>Wed, 21 Apr 2010 00:12:50 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9513&amp;title=browse-window-doesnt-appear#9513</guid>
   <title><![CDATA[Browse window  doesn&#039;t appear : You couldn&amp;#039;t be more right,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9512&amp;title=browse-window-doesnt-appear#9512</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111766">rsuarez</a><br /><strong>Subject:</strong> 3658<br /><strong>Posted:</strong> 20.Apr.2010 at 21:36<br /><br />You couldn't be more right, I changed it and it worked fine. I have no enough kind words to express my gratitude, I was becoming crazy with the thing. THANKS A LOT.]]>
   <pubDate>Tue, 20 Apr 2010 21:36:35 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9512&amp;title=browse-window-doesnt-appear#9512</guid>
   <title><![CDATA[Browse window  doesn&#039;t appear : You need to set your FILEDIA variable...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9511&amp;title=browse-window-doesnt-appear#9511</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 3658<br /><strong>Posted:</strong> 20.Apr.2010 at 21:17<br /><br />You need to set your <b>FILEDIA</b> variable to 1.]]>
   <pubDate>Tue, 20 Apr 2010 21:17:48 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9511&amp;title=browse-window-doesnt-appear#9511</guid>
   <title><![CDATA[Browse window  doesn&#039;t appear : Hi. Using AutoCAD Civil 3D for...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9504&amp;title=browse-window-doesnt-appear#9504</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111766">rsuarez</a><br /><strong>Subject:</strong> 3658<br /><strong>Posted:</strong> 20.Apr.2010 at 18:03<br /><br />Hi. Using AutoCAD Civil 3D for the third time or so, and&nbsp;I wonder why my browse window stopped appearing when I want to open a file, saving or even selecting a new one. It only shows me the filename in the command window with it's whole path, which is extremely uncomfortable because you don't keep all path information and filename in your mind&nbsp;or time so you can afford to re-type it everytime.<DIV>&nbsp;</DIV><DIV>My guess is that a value for a system variable is missing. Anybody have faced&nbsp;the same problem? Thanks in advance.</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Tue, 20 Apr 2010 18:03:43 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3658&amp;PID=9504&amp;title=browse-window-doesnt-appear#9504</guid>
