  <title>CAD Forum discussion (EN) : Rendering with an attached image</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : Inventor : Rendering with an attached image]]></description>
  <pubDate>Tue, 21 Jul 2026 11:02:38 +0000</pubDate>
  <lastBuildDate>Fri, 04 Jan 2008 14:54:04 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=366</WebWizForums:feedURL>
   <title><![CDATA[Rendering with an attached image : It is like sticking the real decals...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=842&amp;title=rendering-with-an-attached-image#842</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 366<br /><strong>Posted:</strong> 04.Jan.2008 at 14:54<br /><br />It is like sticking the real decals on an model - this is quite well explained in the Help.]]>
   <pubDate>Fri, 04 Jan 2008 14:54:04 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=842&amp;title=rendering-with-an-attached-image#842</guid>
   <title><![CDATA[Rendering with an attached image : Vladimir, Can you help with some...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=841&amp;title=rendering-with-an-attached-image#841</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=719">DJMike</a><br /><strong>Subject:</strong> 366<br /><strong>Posted:</strong> 04.Jan.2008 at 14:43<br /><br />Vladimir,<DIV>Can you help with some steps using decals?</DIV><DIV>How do I use it?</DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV><DIV>DJMike</DIV>]]>
   <pubDate>Fri, 04 Jan 2008 14:43:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=841&amp;title=rendering-with-an-attached-image#841</guid>
   <title><![CDATA[Rendering with an attached image : I assume you are using decals....]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=840&amp;title=rendering-with-an-attached-image#840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 366<br /><strong>Posted:</strong> 04.Jan.2008 at 14:33<br /><br />I assume you are using decals. Please note that decals were not rendered in older versions of Inventor.<DIV>You can also use material textures (bitmaps).</DIV>]]>
   <pubDate>Fri, 04 Jan 2008 14:33:41 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=840&amp;title=rendering-with-an-attached-image#840</guid>
   <title><![CDATA[Rendering with an attached image :  To all,  I have created a rectangle...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=839&amp;title=rendering-with-an-attached-image#839</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=719">DJMike</a><br /><strong>Subject:</strong> 366<br /><strong>Posted:</strong> 04.Jan.2008 at 14:19<br /><br /><img src="http://www.cadforum.cz/forum_en/smileys/smiley38.gif" height="17" width="17" border="0" align="absmiddle" alt="Lamp" /><DIV></DIV>To all, <DIV>I have created a rectangle and extruded it to a desired thickness. next I want to attach an image, most likely a *.bmp or *.jpg. This I have done by adding an image. What&nbsp;I cannot do is render the project in Inventor Studio and see the attached image. I have created a texture using a *.bmp for one project and that worked for one application I but need to attach an image for this project. I have attached the image but it disappears when I render the project in studio. I have tried the decal function but the help files are limited and I did not have success with that.</DIV><DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; If any readers know or have an idea of how to get the image to show in a rendered bmp in studio please reply.</DIV><DIV>&nbsp;</DIV><DIV>TIA</DIV><DIV>&nbsp;</DIV><DIV>DJMike</DIV>]]>
   <pubDate>Fri, 04 Jan 2008 14:19:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=366&amp;PID=839&amp;title=rendering-with-an-attached-image#839</guid>
