  <title>CAD Forum discussion (EN) : Need help</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Need help]]></description>
  <pubDate>Tue, 20 Oct 2026 18:01:04 +0000</pubDate>
  <lastBuildDate>Fri, 25 Apr 2008 10:00:00 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=377</WebWizForums:feedURL>
   <title><![CDATA[Need help : You can increase the relative...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1742&amp;title=need-help#1742</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 25.Apr.2008 at 10:00<br /><br />You can increase the relative scale of your dim texts (see Dim Styles), or you can dimension in the paperspace (layout) to keep your dimensions independent on model scale, or you can use a text style with fixed height.]]>
   <pubDate>Fri, 25 Apr 2008 10:00:00 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1742&amp;title=need-help#1742</guid>
   <title><![CDATA[Need help : Hello,  I am trying to print...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1732&amp;title=need-help#1732</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=8915">blackdog</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 24.Apr.2008 at 18:18<br /><br />Hello,<DIV>&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; I am trying to print a drawing (backyard deck plans) that I made with acad2008 to my HP deskjet. When the drawing is reduced the dimensions text is also reduced (so small can't read). How do I print the drawing but end up with a legible font size when printed?</DIV>]]>
   <pubDate>Thu, 24 Apr 2008 18:18:45 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1732&amp;title=need-help#1732</guid>
   <title><![CDATA[Need help : Here is a video showing you how...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1322&amp;title=need-help#1322</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=5659">dictum</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 27.Feb.2008 at 14:36<br /><br /><a href="http://cadcamforums.com/index.php?topic=20.0" target="_blank">Here is a video showing you how to do just that.</a>]]>
   <pubDate>Wed, 27 Feb 2008 14:36:40 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1322&amp;title=need-help#1322</guid>
   <title><![CDATA[Need help : Why not just keep the drawing...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1304&amp;title=need-help#1304</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=5657">Sombra</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 26.Feb.2008 at 23:24<br /><br />Why not just keep the drawing in millimeters and then when you need to dimension, change the dimstyle scale factor? Or, if you're just doing a "dist" (distance) command in autocad, you simply move the decimal place to the right 3 places. Millimeters, and metric for that matter, is so simple and easy to work with, there's&nbsp;no real need to change the scale of the drawing. <span style="font-size:10px"><br /><br />Edited by Sombra - 26.Feb.2008 at 23:25</span>]]>
   <pubDate>Tue, 26 Feb 2008 23:24:24 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=1304&amp;title=need-help#1304</guid>
   <title><![CDATA[Need help : Scale the drawing globally - use...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=897&amp;title=need-help#897</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=1522">LatCh</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 12.Jan.2008 at 17:03<br /><br />Scale the drawing globally - use the SCALE command, select all objects and enter the scale factor.]]>
   <pubDate>Sat, 12 Jan 2008 17:03:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=897&amp;title=need-help#897</guid>
   <title><![CDATA[Need help : thanks .. each time i have to...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=896&amp;title=need-help#896</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3787">anilnavis</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 12.Jan.2008 at 08:59<br /><br />thanks .. each time i have to select the one by one ? to change the measurement ?&nbsp;]]>
   <pubDate>Sat, 12 Jan 2008 08:59:54 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=896&amp;title=need-help#896</guid>
   <title><![CDATA[Need help : You can either just set a multiplication...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=866&amp;title=need-help#866</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3">Vladimir Michl</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 09.Jan.2008 at 15:52<br /><br />You can either just set a multiplication factor in your dimension style, or scale down your drawing 1000x (SCALE command, 0.001).]]>
   <pubDate>Wed, 09 Jan 2008 15:52:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=866&amp;title=need-help#866</guid>
   <title><![CDATA[Need help : Hello i am new autocad i am using...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=865&amp;title=need-help#865</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=3787">anilnavis</a><br /><strong>Subject:</strong> 377<br /><strong>Posted:</strong> 09.Jan.2008 at 15:46<br /><br />Hello i am new autocad i&nbsp; am using the 2006 version<br><br>&nbsp;i have a question. I got a cd design did by someone<br>its units in millimeter . but&nbsp; want to change the unit to meter is it possible ..<br>When i take measurement the length should be in meter is its posssible.<br><br><br>Thanks <br>Anil<br><br><br><br><br>]]>
   <pubDate>Wed, 09 Jan 2008 15:46:59 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=377&amp;PID=865&amp;title=need-help#865</guid>
