  <title>CAD Forum discussion (EN) : 3d ground profile</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : 3d ground profile]]></description>
  <pubDate>Mon, 02 Nov 2026 03:32:56 +0000</pubDate>
  <lastBuildDate>Fri, 28 May 2010 11:46:15 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3803</WebWizForums:feedURL>
   <title><![CDATA[3d ground profile : thanks for the reply.   we did...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3803&amp;PID=9825&amp;title=3d-ground-profile#9825</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=11333">pizzle</a><br /><strong>Subject:</strong> 3803<br /><strong>Posted:</strong> 28.May.2010 at 11:46<br /><br /><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">thanks for the reply. <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" /><o:p></o:p></FONT></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">&nbsp;<o:p></o:p></FONT></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">we did actually used to use civil 3d but had to get rid of it due to lack of use (hence the question) but i think i've found the solution now.&nbsp;<o:p></o:p></FONT></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">&nbsp;<o:p></o:p></FONT></FONT></SPAN></P><P =Ms&#111;normal style="MARGIN: 0cm 0cm 0pt"><SPAN lang=EN style="FONT-SIZE: 9pt; mso-ansi-: EN"><FONT color=#000000><FONT face="Times New Roman">It was only a small area of a site that needs to be modeled so i simply added the z value to the relevant points and used a plugin called 'Point Cloud'&nbsp;that effectively droops a mesh over the points to create the surface. Bit of a ball ache though as&nbsp;i had&nbsp;to manually input the z data, but got there in the end!</P><DIV></DIV><P>&nbsp;</P><P>Cheers</FONT></FONT></SPAN></P>]]>
   <pubDate>Fri, 28 May 2010 11:46:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3803&amp;PID=9825&amp;title=3d-ground-profile#9825</guid>
   <title><![CDATA[3d ground profile : It&amp;#039;s not a simple task. To...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3803&amp;PID=9823&amp;title=3d-ground-profile#9823</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=73469">CarlB</a><br /><strong>Subject:</strong> 3803<br /><strong>Posted:</strong> 27.May.2010 at 20:23<br /><br />It's not a simple task. To do it properly, accuratetly, that would stand up in court, you need information provided by a registered surveyor; a ground model created using industry-standard/approved software such as Civil 3D, eaglepointe, several others; performed by someone with the necessary training.<DIV></DIV><DIV></DIV><DIV></DIV><DIV>&nbsp;</DIV><DIV>OK if you just want a 3d representation you can manually draw elevation contours through the points, make polylines, use methods (autocad commands) to convert to a surface or solid.</DIV><DIV>&nbsp;</DIV><DIV>More accurately &amp; automated &amp; cheap, download program from <a href="http://www.sitetopo.com" target="_blank" rel="nofollow">www.sitetopo.com</A></DIV><DIV>&nbsp;</DIV><DIV>&nbsp;</DIV>]]>
   <pubDate>Thu, 27 May 2010 20:23:37 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3803&amp;PID=9823&amp;title=3d-ground-profile#9823</guid>
   <title><![CDATA[3d ground profile : i seem to be having great difficulty...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3803&amp;PID=9819&amp;title=3d-ground-profile#9819</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=11333">pizzle</a><br /><strong>Subject:</strong> 3803<br /><strong>Posted:</strong> 27.May.2010 at 11:12<br /><br /><P>i seem to be having great difficulty with this simple task... please help!</P><DIV>&nbsp;</DIV><DIV>i need to create a 3d model of an area of land to show how flat (or not flat) it is.&nbsp; I have point data covering the area of interest&nbsp;that has the 'z' value already entered so all i need to do is create a 3d surface from this information right?</DIV><DIV>&nbsp;</DIV><DIV>how does one do this?</DIV><DIV>&nbsp;</DIV><DIV>Many thanks for any help</DIV>]]>
   <pubDate>Thu, 27 May 2010 11:12:29 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3803&amp;PID=9819&amp;title=3d-ground-profile#9819</guid>
