  <title>CAD Forum discussion (EN) : Quick aligned Dimension</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Quick aligned Dimension]]></description>
  <pubDate>Sun, 06 Sep 2026 13:21:48 +0000</pubDate>
  <lastBuildDate>Wed, 01 Sep 2010 01:34:34 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=3938</WebWizForums:feedURL>
   <title><![CDATA[Quick aligned Dimension : I&amp;#039;m not surewhat is your...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3938&amp;PID=10840&amp;title=quick-aligned-dimension#10840</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=23520">p3.1416l</a><br /><strong>Subject:</strong> 3938<br /><strong>Posted:</strong> 01.Sep.2010 at 01:34<br /><br />I'm not sure&nbsp;what is your question but you have 2 methods: dimlinear and dimaligned wich produce different dimensions.<DIV>Dimlinear will provide the same results as qdim.</DIV><DIV>Dimaligned will provide dimensions aligned with the object, i.e. the true dimension of the object</DIV>]]>
   <pubDate>Wed, 01 Sep 2010 01:34:34 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3938&amp;PID=10840&amp;title=quick-aligned-dimension#10840</guid>
   <title><![CDATA[Quick aligned Dimension : Can anybody tell me if there is...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3938&amp;PID=10090&amp;title=quick-aligned-dimension#10090</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=4476">jmontesmx</a><br /><strong>Subject:</strong> 3938<br /><strong>Posted:</strong> 01.Jul.2010 at 04:44<br /><br />Can anybody tell me if there is a command to&nbsp;obtain aligned dimensions of lines, etc. like the quick dimension command that give linear dimension but no aligned.<DIV>Any information will be apreciatte.&nbsp;</DIV>]]>
   <pubDate>Thu, 01 Jul 2010 04:44:15 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=3938&amp;PID=10090&amp;title=quick-aligned-dimension#10090</guid>
