  <title>CAD Forum discussion (EN) : Block Attributes Vanishing</title>
  <description><![CDATA[This is an XML content feed of; CAD Forum discussion (EN) : AutoCAD : Block Attributes Vanishing]]></description>
  <pubDate>Sun, 14 Jun 2026 06:06:58 +0000</pubDate>
  <lastBuildDate>Thu, 15 Jul 2010 07:45:39 +0000</lastBuildDate>
  <WebWizForums:feedURL>https://www.cadforum.cz/forum_en/RSS_post_feed.asp?TID=4000</WebWizForums:feedURL>
   <title><![CDATA[Block Attributes Vanishing : i try to audit and i found zero...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4000&amp;PID=10252&amp;title=block-attributes-vanishing#10252</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=96808">kadkal</a><br /><strong>Subject:</strong> 4000<br /><strong>Posted:</strong> 15.Jul.2010 at 07:45<br /><br /><P>i try to audit and i found zero errors,&nbsp;i was wondering&nbsp;how they did this (client) when im creating attributes in my own&nbsp; i didnt experience this....yes, undo will work&nbsp; but i need some changes in the drawing<img src="http://www.cadforum.cz/forum_en/smileys/smiley19.gif" height="17" width="17" border="0" align="absmiddle" alt="Cry" /></P>]]>
   <pubDate>Thu, 15 Jul 2010 07:45:39 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4000&amp;PID=10252&amp;title=block-attributes-vanishing#10252</guid>
   <title><![CDATA[Block Attributes Vanishing : This happens to me sometimes,...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4000&amp;PID=10243&amp;title=block-attributes-vanishing#10243</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=111013">Cad64</a><br /><strong>Subject:</strong> 4000<br /><strong>Posted:</strong> 15.Jul.2010 at 01:56<br /><br />This happens to me sometimes, and when it does happen, I just UNDO&nbsp;immediately after running ATTSYNC. This usually fixes the problem. <DIV>&nbsp;</DIV><DIV>Have you tried running an AUDIT on the drawing to check for errors? Also AUDIT any xrefs that may be attached.</DIV>]]>
   <pubDate>Thu, 15 Jul 2010 01:56:06 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4000&amp;PID=10243&amp;title=block-attributes-vanishing#10243</guid>
   <title><![CDATA[Block Attributes Vanishing : I have a Block Attributes in a...]]></title>
   <link>https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4000&amp;PID=10213&amp;title=block-attributes-vanishing#10213</link>
    <![CDATA[<strong>Author:</strong> <a href="https://www.cadforum.cz/forum_en/member_profile.asp?PF=96808">kadkal</a><br /><strong>Subject:</strong> 4000<br /><strong>Posted:</strong> 13.Jul.2010 at 07:32<br /><br />I have a Block Attributes in a drawing that was recieved from the client, then i&nbsp;made some changes in it (attributes) my question is when i try to update it using&nbsp; ATTSYNC command the whole block attibutes vanishing or disappear...any solution with this?]]>
   <pubDate>Tue, 13 Jul 2010 07:32:09 +0000</pubDate>
   <guid isPermaLink="true">https://www.cadforum.cz/forum_en/forum_posts.asp?TID=4000&amp;PID=10213&amp;title=block-attributes-vanishing#10213</guid>
